Rusty wing
  • Rusty wing
    Hi guys,I have a one owner from new astra h VXR in star silver.
    2 small bubbles on passenger wing,nothing major.
    I removed the arch liner to find hidden underneath the foam padding a load of moist mud.
    Cleaned all out and rust at back of wing at the bottom not too bad.
    Do I get it repaired or bite the bullet and buy genuine wing £170 because I do not want a crap after market one.
    Remove your arch liners boys and girls and clean out asap.
    Thanks Steve
    What side drivers side or passenger side? and where is the foam. i need to check mine thanks for pointing it out.
      Yes, 100% agree with you. Both front and rear arches out and give it a good clean & treatment as necessary.
      fastcar the foam mentioned is on both driver & passenger sides at the rear of the wheel arch, behind the plastic liner.
      I'd recommend once removed & cleaned, treat with something like Bilt Hamber Dynax (UC or UB), let it sit for 24 hours before refitting.
        Thanks Ant i need to get onto this, cant stand rust.
