problem perhaps?
  • problem perhaps?
    Does anyone else find that if there stationary, rev the car to lets say 3k rpm slowly that at 2k rpm upwards theres a wierd noise, kind of like vibrating? or is it me being particular?
    Could be a loose baffle in the exhaust?
    Astra
      sounds more front end! its probably nothing but thought id check to see if anyone notices this?
        Could be just the flexi joint being noisy or even something resonating off the exhaust?
        Worth having a listen with it on a ramp
        Astra
          yeah, im off to thorney in 2 weeks, is this something theyd check for me?
            Am sure they would if you mention it
            Astra
              Yeah make sure you mention it when you come in. We've seen a few where its just a loose bolt on the airbox cover, little noises can sound pretty big if the resonance is right.
                ok brilliant, thanks mate
                  Is it like pitched whining noice ?
                  If so read this threat http://www.vxronline.co.uk/forum/showthread.php?t=63445
                  I have this sound have something to do with the piston cooling nozzels in the engine, but does not do any harm they say
                    Could even be the metal exhaust manifold gasket resonating.
                      i dont think its anything major, its just one of those things thats bugging me and if it is something then heopfully it can be sorted easy enough, thanks for the input though!
                        yes mate i get that. did u find what it was?
                          did you have the aircon switched on at the time, if so that will be it
                            My aircon is the same turn it off and the noise stops
                              I had this and vauxhall just told me yesterday that it was my cat, there replacing the sports cat under warrenty tho, but was exact same as what your describing
