Sport Button??
  • Sport Button??
    in reality if the car is in standard guise does pressing this actually do anything noticable???
    Yes, it puts an LED on - very noticeable
    If you have IDS+ it stiffens the ride and makes the steering slightly heavier.
    Other than that, the throttle becomes more sensitive.
    ...and if you hold the button, you loose the stability program.
      sorry mate LED, IDS??
      REALLY MUST MAKE THE TIME TO READ THE HANDBOOK
        Sorry, when I said LED - I was mucking about - the light on the button
        IDS+ is Continuous Damping Control. If you have this option then you will see IDS+ lit on the dash when you switch the ignition on (and I think also when you open the driver's door).
          lol - no probs
          IDS - unless it is standard my car hasnt got it
            If you have IDS+ and IDS+ light comes up on the dash when you turn the ignition on.
            Clique #14
              It kicks the remap in on mine. VERY VERY noticable indeed.
                just slightly more throttle responce really when you hit that button on a standard car.
                Who drives with ESP off... I tried it and its a completely different handling car.
                over 1 year now and im just learning to take it off when dry days. dont notice much difference to be honest.
                  Completely different handling car? No this is just because the ESP is no longer saving you from every ditch and tree in sight?
                  Clique #14
                      Is it really only IDS cars where the suspension stiffens? I am sure my Zaf suspension hardens up, but it hasn't got IDS.
                        You have a car with that much power, and cant even handle it with the traction control off?
                          Push it and find out for yourself mate
                            yes it does , quicker acceleration response , stiffens suspension up and a shorter wheel turn ,
                            as Rossi said , go try it
                              when you push it you can see the rev counter move up an feel the car surge a little,or maybe thats my noz button
