Does any one have instructions on how to remove the door cards. need to remove them think i have some loose clips in it
Door Cards
I have been trying to find this out myself. Need to find out how to remove rear trim aswell need to get a few dents removed. I think the door cards have some torx screws that need unscrewing including one behind the door handle.Oh My god Nissan what have you done? You haven't created a machine
You just made a MONSTER!!!!
Astra vxr 19's, cd70+cid+aux in, bluetooth, climate control, parking sensors. Retro fitted:- afls, headlamp washers, cruise control, check control, sight and light, folding mirrors, anti hi-jack, vx-racing edition full leathers, cid video interface, reversing camera
Originally posted by s4rpf View PostDoes any one have instructions on how to remove the door cards. need to remove them think i have some loose clips in it
Pop out the window control switch and check for some there and if you look kind of inside the pull handle for openning the door there will be a wee flap so pop that open and there will be a screw or tork there.
Then pop the mirror trim off (the one with the tweater) and check under there and if that all off then try popping the door trim off at the bottom in one of the corners and it should pop off and lift up.
One word of warning is that if you are inside the door and you burst or tear any of the plastic shower curtain tape it back up with and make sure it sealed back up as it a water leak waiting to happen.
The quater trim is another storey id have to have a look to see how that comes off...
Originally posted by nellynell View PostI have been trying to find this out myself. Need to find out how to remove rear trim aswell need to get a few dents removed. I think the door cards have some torx screws that need unscrewing including one behind the door handle.
Originally posted by W4GCN View PostIll try and get a look tomorrow and let you know how they come off pal...Oh My god Nissan what have you done? You haven't created a machine
Originally posted by nellynell View Postcheers pal that would be helpful. If all else fails i think il have a look in the haynes manual that should explain it.
Last haynes i had was for a Nova...
I need to take mine off for dent devil to pop a wee shopping trolley dent out, bloody annoying...
I need to take mine off for dent devil to pop a wee shopping trolley dent out, bloody annoying...Oh My god Nissan what have you done? You haven't created a machine
