how do you exstend the air flow meter
  • how do you exstend the air flow meter
    as above need to make it a bit longer for the air box mod how do i do this ?????
    many thanks Richard
    many thanks Richard
    cut it, have spare wires, solder them together, then solder then other end then wrap up the bear wire bit with insulation, then cover with heat insulation.
      You could do what I did I striped down the plug on an old amm and managed to get holed of the plug off a loom for the amm (not an easy job) and made up an extension so I did not have 2cut my loom. Best bit is I can just take at my air box and no one will ever know it was there and should b nice and easy to sell on.
        Don't forget to put the heat wrap sleve on first before soldering it all together other wise ya won't be able to put it on.
          and i thought it was going to be easy lol
          thanks for the advice guys
            well if you have used a soldering iron before you find it easy enough. if not id ask some one to give you a hand.
              think i might have to
