yes hes just fitted the forge(?) one which is why im assuming he doesnt feel a bog difference from before. so if he hasnt readded the map etc may not feel much better.
i mean cooler will added a few bhp but not a load.
i think 99% of people who have intercooler fitted have stage 3 map.
its would be like having a turbo back exhaust on stage 1 map you dont get the full benefit of the modification until the map is changed to suite the mod
tom im sure if you speak with dave he will point you in the right direction on how to get the map re-done.
could always speak to courts an see what they can offer.
but id defo get the stage 3 map for it as that is the map that is designed for a bigger cooler, as you will get the most out of the set up.. if you get what i mean.
any changes that could improve performance after a map will need re-mapping to suit what changes you`ve had done , in your case tom you`ll need a stage 3 map to get the best out of what you`ve had done . if your planning anymore mods i`de wait untill all mods are done before you get it re-mapped
i have spoke to dave and he said there is not much diff in the maps and said wait a month or two cos the stage 2 map is the same and its the hardwear that makes the difference
Dave (DAP) should sort you thestage 3 map out and it should be a free upgrade. I know he isnt trading anymore like before but he did say he would still look after his previous customers. You just need to get hold of him................good luck with that
