im running a stage 3 map took the car out 4 a spin tonight and the car was spluttering in 2nd and 3rd when i was giving it the beans,but it wasnt losing ne power has ne 1 had this b4,i checked the error codes and 124358 was coming up
help
Originally posted by vxrmadmatt View Postim running a stage 3 map took the car out 4 a spin tonight and the car was spluttering in 2nd and 3rd when i was giving it the beans,but it wasnt losing ne power has ne 1 had this b4,i checked the error codes and 124358 was coming up
P1243 turbocharger bypass solenoid valve voltage too small C-033
P1243 turbocharger bypass solenoid valve open circuit C-033
P1243 turbocharger bypass valve not in the target area C-033
sounds like a boost solenoid problem, or could maybe sparks on way out
sure boost solenoid is aprox £15 plus vat.
cheaper on vauxworldparts.co.uk think is called
plus problems,
http://www.classictruckshop.com/club...park/plugs.htm
hope that helped
Originally posted by vxrmadmatt View Postchanged over maf sensor all seems ok .but when it was in standard mode it was ok ,it was just in sport mode it was spluttering cant make sense of it
need changing, or need regapping if there new
