Coolant Hose change.. help/advice required...
  • Coolant Hose change.. help/advice required...
    Hi peeps,
    I've just taken delivery of some very nice silicone coolant hoses from Forge Motorsport..
    However it's been years since I've done a coolant change etc. on a vehicle so was wondering if anybody else have done this type of job and has any instructions about re-filling the system? (ie, do you just re-fill the expansion bottle then run up until thermostat opens and top up as neccesary?)
    I don't want to cause any damge but not filling the system adequately..
    Any help or pointers will be appreciated..
    ta
    Tony
    Auto Inparts.com
    exclusive automotive products
    www.autoinparts.com
    www.e-tech.uk.com
    GREEN COTTON FILTERS,
    ETECH, SPARCO, PRECISION ENGINEERED WHEEL ACCESSORIES, MUC-OFF
    Originally posted by TonyJ View Post
    Hi peeps,
    ta
    Tony
    yeah re-fill it up, run it for abit, then top it up when cooled down a bit if needed. no points sound like you know what your doing
      Cheers mate..
      Auto Inparts.com
      www.autoinparts.com
      www.e-tech.uk.com
        Dont forget to tighten up any Clips
        I would be the same i want some pipes but not done a new engine coolant hose change before
          when ya fill the system run it for a bit but put your heaters in the car on full and when they get hot the system is bled make sure ya let the fan kick in then top up if needed
            Nice one.. cheers
            Auto Inparts.com
            www.autoinparts.com
            www.e-tech.uk.com
