had the same prob with mine pal 42011 is the exhaust emissions try changing your fuel if you are running it on v power .. i changed to tesco unleaded now theres no prob.. its something to do with your parameters on the ecu not being wide enough usually happens to the cars with a remus fitted... take off your battery lead and run the fuel down to nothing then fill back up with a different fuel to see if the light comes back on... if u take it to vauxhall they just clear your error codes and send you on your way
