Suspension help please
  • Suspension help please
    Hi folks had a hollow type bang/knocking noise from front drivers side of the car when a go over pot holes or bumps for few days now think it might be something to do with shock absorber??? any thoughts?? also when a tried to rock the car by hand on front wings it moves up and down lot more easier this side other than passenger side, car is lowered on eibach sportlines( was done by 888 before a got car from dealer when new so would this be covered under a warrenty if it is shocker thats goosed??) doubt it tho prob just wear n tear
    If anyone thinks they no what it is please say before a get car in to get checked asap
    Astra VXR,Focus ST,Astra VXR Burg 326,Focus RS,Bmw 3 Series Convertible
    And now have an
    Astra GTC VXR in Arden Blue
    Aero kit, AFL premium forward lighting, Sat nav, Dark rear tinted windows, Electric folding mirrors and Rear parking sensors
    could be track rod end or drop link what ever people call them on these. jack car up wiggle the wheel see if theres any play.
    check all bolts around suspension area tight. check engine mounts aswell as can cause it to bang and move
    spring could be turning causing it to twang. happend in my vectra stripped it, cleaned and oiled moving parts put back together and solved it. was dread it was a snapped spring
      No play in wheel checked that, just because a can push car down lot easier and more on drivers side thats why a think it might be shocker or spring
      And now have an
        check things i said not sure how to check the shock, sure one is the seals on it. sure someone will answer soon.
          Awrite thanks mate, gona get it into my local vx specialist to get it looked at (not stealers dnt trust them near me)
          And now have an
            spring could have completely snapped happened to a golf gti I had and had symptoms similar to that!
            Originally posted by soosie
              hmm awrite could be that aswell a suppose, car dont feel diff really to drive tho
              And now have an
                already said could be lol. wont be it does proper twang, and it be dropped like mad
                  when the spring went on my VW there was no noticeable difference to drive but hellish noise on full lock and going over any bumps. Put your hand behind the wheel and see if you can jiggle the springs , if u can the spring will be bungalowed!
                    My drop links are being replaced on the corsa, same knocking nose because its lowered.
                    Rabbid Tuned - WG Motorworks
                    www.wgmotorworks.co.uk
                      Update soz its took so long but been working flat out last wee while, went to get looked at today and turns out its actually the passenger side thats the problem so would never have found it a was convinced it was drivers side but full points to most of you as it was drop link as said above that was the problem so its all sorted now no more bangs over the holes or bumps in road
                      And now have an
                        Glad to hear your motor's all sorted now Brian! x
                          Was in two mind what to do as all ave ever had is bad luck/service from local dealers but since we moved to our new house a thought ad give it one last go with dealers to see what was wrong and must say had really good service and found/fixed it in half an hour or so. also surprised it was covered by vx as car has been lowered altho it was vxrpc that done the springs so mabye that keeps warrenty on it
                          All sorted now tho and happy with the car again now, esp as left service bit to find people looking in window and checking car out, love when that happens
                          And now have an
                            Yeah, makes you feel proud to have such a cool car . Great to hear the house move has been a good one, too. x
                              yea moved near a good dealer so all good lol
                              And now have an
