astra vxracing hoses
  • astra vxracing hoses
    hi i have purchased a boost pipe and the vxracing hoses that come with it but i have also purchased an enlarged tophat and wanted to know if anyone knows were i can purchase a vxracing hose that will fit the standard boost pipe but with the enlarged other end for the bigger tophat cheers
    ASTRA nurburgring mods; itg panel filter, white samco hoses, cruise control, remus
    I actually think I have what your looking for
    What sizes do you need both ends to be, i'll check it for you.
    Its a samco hose
      dont actually know bud but it is the standard size at boost pipe end and will fit the courtenay larger tophat at the other end if you know what i mean
        I know what you mean mate, assuming that the courtney tophat plate is the same size as Percy's one, then it will fit.
        Its a black samco hose.
          i am after a blue one with vxracing on if i can get it as the other ones have this on and want to try and get the same if i can and was wondering if anyone knew were i could get this from cheers anyway
            I want a full set of VXRacing hoses in blue... where can you get them?
            Ignorance is temporary... Stupidity lasts forever.
              No probs, its there if you need it, don't want much for it like, its only sitting around.
                if i cant get the one for the enlarged tophat i might have two for sale bud
                  oOo well keep me posted
                    cheers if i cant get sorted might have this off you will let you know when i find out if i can get them or not
                      ok will do
                        anybody know any were that will do these cheers
                          i have some in the for sale ads
                          Griffin autos Bedfordshires only independent vauxhall specialist 01525 402896
                          Salvage/Damaged/Non runner Vxr's Wanted
                            somebody must have an idea of were i can get one from
                              check ebay m8, not specifically for the astra but ive saw hoses with 1 side smaller diameter than the other
