from pro sport mechanical boost, i have everything but pod as im still looking for a nice one. anyways how can i see it what it looks like when lit up without fully fitting it? can i run it off car battery or similar so it lights up? there is red orange and black wires
boost gauge arrived
anyone?
also i guess oil temp is another good one to get fitted, but what about others like exhaust gas temp or air to fuel ratio or fuel pressure?
how much are these to get fitted cause i aint got any ideaAstra vxr mk2 with stage 1 EDS remap
heres the ones available
http://www.lbperformance.com/index.p...ex&cPath=79_97Astra vxr mk2 with stage 1 EDS remap
eg temps a really good one, but there noy cheap an you need to mount / weld the boss on one of the cylinders on the manni to get best an most accurate reading...
afr is another good one but same again you need to get the boss welded in the exhaust..my build thread - http://www.vxronline.co.uk/forum/showthread.php?t=90714
get the air to fuel mate. oil temp, and boost guage
i wouldnt fit the exhaust gas and fuel pressure.
thats what i had on my turbo corsa
Mate wiring on the prosport 3 wire gauges are:
Red - Switch live
Black - Earth
Orange - illumintation
Also for 4 wire electrical gauges-
Green - sensor
If you just wanna see what its like, put the red on battery positive and black on battery negative and be careful not to short anything out!
I tried my new gauges on my power supply at work, if you put green wire with the earth you can see the sweep (providing its an electrical gauge)
I got boost/oil pressure/ oil temp/ af ratio
Originally posted by regalvxr View Postkeeno have you decided where your mounting all these gauges?. May well be fine to put them on there tbh but until i get stuck for ideas i'm going to put gauges where i have said
Originally posted by regalvxr View Posti can see oil temp and boost being useful but not sure bout the rest to be honest
Originally posted by Keeno View PostYeah oil temp, af and oil pressure going into my 3 gauge conversion that i'm trying to sort out at the moment and boost is going on steering column cover. I'm a bit unsure of putting them on the pillar, although airbags are in roof when they deploy the pillar cover comes off or away i believe. May well be fine to put them on there tbh but until i get stuck for ideas i'm going to put gauges where i have said
also any idea on what someone would charge to fit boost and oil temp guage as oil temp sounds like ypou got to plumb it in. does oil gauge come with everything needed to fit??Astra vxr mk2 with stage 1 EDS remap
Originally posted by regalvxr View Postwhat about water temp mate???
whats vacuum for?
volts and exhaust gas temp seem silly
Volts is more for show if you want somthing thats looks good and fills a hole
Exhaust gas is for very highly tuned cars really and is very pricey to buy and to fit
I didnt see the point in water temp, it doesnt tell you how hot the engine is? Thats oil temp. Yeah it will tell you if your coolant overheats due to a leak or something but oil temp can do the same i guess. After a blitz the water temp may say 85 or something but the oil may still be cooking...
