right i have just had a garret conversion on my astra new exhaust stage 4 mapping etc but i seem to be having a rattle coming from my wastegate so i checked the wastegate and the wastegate flap was loose i could move it about but im pretty sure that this is supposed to be setup closed and not loose so i took the slack off of it at the same time not putting extra any pressure on it now it is overboosting an extra 5 psi does the map need adjusting to suit this???
wastegate rattle
same as above... whos done the work mate? sounds like you have a nice engine, what power you making?my build thread - http://www.vxronline.co.uk/forum/showthread.php?t=90714
did you get this sorted mate?my build thread - http://www.vxronline.co.uk/forum/showthread.php?t=90714
whats full spec of it? you using a tubular manifold an had engine rebuild?my build thread - http://www.vxronline.co.uk/forum/showthread.php?t=90714
sounds good to me, yeah engine should be fine, as it sounds like your running low boost so internals should be ok...my build thread - http://www.vxronline.co.uk/forum/showthread.php?t=90714
