As there has been quite a few people suffering with manifolds cracking not just with the vxr but also other models that run the same kind of set up as the Astra, Corsa, from research I’ve been doing I’ve found that most manifolds tend to crack due to extreme heat collection in the oe manifold, an with the mk 4 gsi it used to kill piston 3, so I’ve been thinking we need a tubular manifold making that houses the oe turbo...
The main benefits running one would be that the turbo would maintain boost further up the rev range an would also help better spooling and feel more responsive, also it would help get heat further away from the engine an wouldn’t be as restrictive as the oe cast one.
The dbilas cast manifold sells at £762.
If there was on option out there in the form of a tubular manifold that housed the oe turbo how much would people be willing to pay? would be cheaper than the dbilas one....
feed back welcome
feed back welcome
