Hi all. i have fault code 42011 come up again, its something to do with cat efficiency. its becoming more regular now that this code comes up i normally just take it to the dealers an they clear it but then couple weeks later an its back. Could the cat be knackered? is there anything else that could be causing this?? oh i have a remus exhaust
Fault code 42011
Fault code 42011
TMS Bluefin Stage 3, Lower mount intercooler, Remus, TMS Alcons, LSD, KW V3's, ITG Filter, Iridium Plugs, Blue SMD Conversion, AFL, Climate, Cruise, S&L, Bluetooth, CD70
www.thorneymotorsport.co.ukTags: None
I got this all the time even with my 200cell cat. Since the stage 3 map went on it hasn't come back, fingers crossed.
In regards to getting your dealer to clear the code, you can do this by disconnecting the battery for 10 minutes, might save you some time rather than bringing it in to them.
As Ian said, there are maps that will help fix this or there are a few other ways around it manually but i'll leave those explanations to someone who knows exactly.sigpic
im sure the exhaust has gone quiet since the code appeared. all i get now out of the remus is little farts every so often an no popping. the code is still stored now. im off to tms friday so will ask them about itsigpic
Originally posted by evertonian View Postim sure the exhaust has gone quiet since the code appeared. all i get now out of the remus is little farts every so often an no popping. the code is still stored now. im off to tms friday so will ask them about it
Originally posted by IanJ View PostThey will say what I have posted in post 2 I reckonsigpic
ASTRA nurburgring mods; itg panel filter, white samco hoses, cruise control, remus
