Is the air intake from a vectra C any bigger than the standard astra VXR one?
Vec C air intake
The air intake for diesel Veccy C is bigger than the Astra VXR one (part number from VX 9177099) but it's not a that much bigger and it would also need adapting slightly to make it fit HTHx
sigpicWas TV Mag Featured Astra VXR Nurburgring Edition 353, gone but not forgotten. Current car MY15 RR Evoque Dynamic SD4 Zanzibar Bronze with Black Pack, Magnetic Ride, 20" Forged OEM Stormer Alloys, Fully Loadedxx
Originally posted by PaulieMB View PostThe air intake for diesel Veccy C is bigger than the Astra VXR one (part number from VX 9177099) but it's not a that much bigger and it would also need adapting slightly to make it fit HTHx
Astra VXR, Power Red with Hints of Gloss Black and the full PPP setup...... NOW GONE
Mazda 3 MPS Aluminum silver. Standard for now......
Astra CDTI 200 bhp No smoke No poke!!
If in Doubt Flat Out 'Colin Macrae'
I have a Dbilas replica one, it is the same, but only £50 from a guy on ebay, much bigger than the vectra one, Although it wont fit with the standard IC as the pipework gets in the way, but i'm sure you could somehow squeeze it in, but would probably require cutting the slam panel, mine is currently off the car as I have the OE intercooler back on, so I will see if it can be made to fit, if I get chance
Originally posted by VXRDean View PostI have a Dbilas replica one, it is the same, but only £50 from a guy on ebay, much bigger than the vectra one, Although it wont fit with the standard IC as the pipework gets in the way, but i'm sure you could somehow squeeze in it, but would probably require cutting the slam panel
x
Originally posted by PaulieMB View PostDean, I take it the Dbilas one fits okay with an aftermarket FMIC?x
Originally posted by VXRDean View PostYeah will fit with no probs, If you buy the one off ebay which is the same, you have to either make your own bracket or use some self taping screws, although I just used tie wraps when I fitted itx
Originally posted by Abbo View PostI've got the Vec C one on, can't even fit a finger into the standard one, can fit most of my hand up the veccy oneOooo err
Cheers Dean just thinking this will go well when i get m new air box ;-)Astra VXR, Power Red with Hints of Gloss Black and the full PPP setup...... NOW GONE
