Consequences of a de-cat?
  • Consequences of a de-cat?
    I know that apart from the obvious it will fail an mot and the emmission light will show up are there any other effects to a de cat? Is it safe to drive around with the emmission light on?Cheers
    oh nooo! wot you planning now!! :P
      Besides what youve said theyre all good!
        I have mine de-cated and maped the lights away dont have any promblems and the car spools alot faster and sounds ok
          i tried full decat and hated it, sounded w*nk and felt like id got no torque, i did feel more revy though, removed the decat the very next day
          Stage 3 Arden Astra gone
          Stage 2 burg
            it wont sound as good normally but im all fro purpose!
              cant you just turn the light off with a tech 2 ebay jobby ? or does it keep comming back ?
              JOIN THE FIGHT!!!
              http://www.facebook.com/group.php?v=...d=371188528552
              DONT JUST SIT THERE AND MOAN.... JOIN THIS AND AT LEAST SHOW YOU CARE!!!!
              EVERY NAME COUNTS PLEASE HELP!!!!
                Yes it much better to rev it, and spools much faster
                But loose of torque i dont why poeple say that i havent felt any thing like that
                Yes you can turn it off, but it will come again
                You have to blcok the sensor or put a de-cat map i have that i mine and the light has not come again
                  you leanr something new everyday andriano never knew there was such a thing as a de-cat map
                  JOIN THE FIGHT!!!
                    A "de-cat map", my guess is that, it is a map written with the parameters which are very wide. For instance, if the tolerance of a standard map is -5 to +5, re-maps could be -10 to + 10, so, a de-cat map, could be -50 to + 50, of the target value, well, just my guess, lol.
                      possibly, I did read up on remapping / winols before tho I never came accross a decat map but Id also guess the same
                      JOIN THE FIGHT!!!
                        I think so i have never tought of this way though haha
                        It is basicly the same map, just spesiflcly written so you dont need any cats and wont get fault codes and lights up,
                        The O2 sensor is kinda block or lets MUCH more emmisions get through with out thinking the cat is broken
                        I now that IPF unit has some de-cat maps on it
                        But before you think of putting a de-cat map on car with cat speek to the tuners as there could be some diff in the maps
                          Do you lose power by de-catting? I always thought you gain power by doing this
                            I have not found any loss in power just more power tbh, and the turbo spools faster
                              Can you tell the difference in the power though? What de-cat could i use for a Milltek race? Is there no one who has had any problems de-catting the VXR?
