Just been fitting my dv 26,i noticed that the vacum pipe coming fromt he fuel regulator t`s off and goes to the manfold and the other pipe goes down a bit further and has a 90 degree rubber join and plumbed inot nothing..where should this go..i cant even upload a photo as its to hard to get camera into...
vacum pipe
are you getting a strange noise on gear change, like a chatter? could be the pipe which goes onto the vacume box, you will need to jack the car up to refit it, worth gluing it too. You will be down on power too if its that pipeVXR gone Audi A6 Avant - Le Mans in
you can refit from above the engine, although its a pain to find the nipple it fits on to just by feeling, ive done it this way tho, twice (it WILL come off again eventually if you dont secure it)Stage 3 Arden Astragone
Stage 2 burg
....................Arden Astra.....................
Originally posted by R34nel View Postyou can refit from above the engine, although its a pain to find the nipple it fits on to just by feeling, ive done it this way tho, twice (it WILL come off again eventually if you dont secure it)
yes it was the pipe righ ton the bottom,refitted it and finished fitting d/v....on idle it sounds like i have a boost leak,but i have checked everyhting and i cant pinpoint it...is this normal??when i rev car it still dumps fine and hiss dosent get any louder
Originally posted by stuuyh View Postyes it was the pipe righ ton the bottom,refitted it and finished fitting d/v....on idle it sounds like i have a boost leak,but i have checked everyhting and i cant pinpoint it...is this normal??when i rev car it still dumps fine and hiss dosent get any louder
