Has anyone on this forum replaced their ecu with a Haltech ecu? surely this would get optimum results over a box tune on the stock computer.. Tuner critical of course...but even so, if your sensible and not chasing massive KW's (or BHP's) - its should be right yes?? Does anyone know if the Platinum is compatible with the vixer engine?? I am on the brink of doing this to finish my stage 3 vixer to get it spot on and finished right. I am over annoying power curve glitches on the dyno.. Any thoughts, comments are welcome.
Haltech ECU on Astra VXR's
Your problem is integration, can it handle fly by wire throttle ?
you'd probably have to leave the stock ECU in place to sit on the CAN. Its going to be messy and alot of work.
A mapper should be able to work with the stock ECU just as effectively.
Originally posted by Crafty View PostYour problem is integration, can it handle fly by wire throttle ?
A guy in Melbourne has an Astra G SRIT and is very happy with his Haltech ECU and tune...how would this be different to mine?
I am interested in your comments - can you just explain it as best as possible in simple terms as I need to understand exactly what you mean.
Cheers.
Basically its gonna be alot of hard work and to be honest not sure if it could be done without leaving the original ECU in,
In basic terms Because of the canbus system in our astra's all the ecu's are linked and talk to each over. If one is removed or goes faulty, more importantly the engine ECU which is what you want to remove the the car is crippled. Everything relates and talks back to the main engine ecu and without it I dont think the car will run.
Could prob bypass the fuelling/boost side of things with a standalone ecu but as said would be difficult, but Im sure it not impossible if you have deep enough pockets.
What Phatashki said. You could do it - just let the haltech control fuel/ignition/boost, the stock ECU would stay in place to pass data through the CAN. It would be interesting to see what happened with ESP as if a slide/wheelpin was detected it'd ask the engine ECU to shut throttle, you wouldn't want this to happen if the Haltech is running the engine.
I know that MoTech can talk to a fly by wire throttle, not sure aboout Haltech, they aren't massively popular over here.
In short you can do it, and you could do some more interesting things, like run load off of map sensor and make the MAF redundant.
Another option I can think of is speak to someone like Jon @ Courtenay and/or Stefan @ Klassen (they work together). Im sure they could help you out without having to go standalone? Stefan has a wealth of experience with the ECUs. Maybe you can buy some dyno time locally and they could sort out a bespoke map remotely.
See Total vax issue 101, similar thing has been done when the guy dropped a vxr engine into a vectra. Thats the Omex 600 management unit.Zaffy VXR| RARB | Vxracing 19s in Gloss Black |Stage 3丨Turboback Miltek 丨TX Intercooler丨CDTI set-up with Pipercross Open Cone丨Forge Recric Valve 丨 Debaged 丨Corsa Indicator Surroundings |Full Rear Sunblinds | Leds Footwell Lightings丨
Originally posted by Crafty View PostAnother option I can think of is speak to someone like Jon @ Courtenay and/or Stefan @ Klassen (they work together). Im sure they could help you out without having to go standalone? Stefan has a wealth of experience with the ECUs. Maybe you can buy some dyno time locally and they could sort out a bespoke map remotely.
I have already contacted Haltech re: issues relating to fly by wire throttle - but will have to wait until Monday for their response. my local tuner is very willing to work with a UK tuner, but just have to work out the details and willingness of people to do this kind of remote tuning.
I have met Jon and Richard at courts on a recent trip home to the UK and bought my diff off them - I sent an email half joking about tuning my car remotely - but if it is possible - this would be great. I have a local dyno dynamics set up about 5min drive down the road - my only question is how klassen or courts deliver the tune(s) during the process to get it right - if they were even able or willing to do this.
its late here - so thanks for the replies and I will see what else comes of it over the next few days.
Cheers again.
Originally posted by CNBLU View PostHaltech will handle fly-by wire no problems, i have one on my SRiT but im yet to compare it to one of the big tuners maps.
The only reason i got a Haltech was because here in Melbourne there are no tuners that can 'live tune' the Bosch ME 1.5.5
Yes very happy.
Mines is going to HP-F for a re-tune in a week. As long as the tuner has a good rep and is well known then 9/10 times you will be happy. It might be a bit pricey but at the end of the day its the tune that designed for your car, not a generic map.
Haltech are one of the best IMO
So I guess based on replies so far - I could have issues with a Haltech on my VXR - or at least make a lot of work for myself. I guess my question would be How are the VXR and SRI Turbo different (Is it the same engine?)- or CNBLU - was the SRI-T a lot or work to get the engine management right on a Haltech?
Appreciate the replies to date by the way.
Is Haltech not popular back home in the UK because as mentioned it is a pain to override or intercept without problems? or has it not really been tested too much because with all the tuning facilities on the stock ecu available there - there is no need?
So you can see where i am coming from and questioning - in Australia, we do not have the numerous options you guys have there - and every tuners answer is to replace or intercept the ECU..not because the stock ECU is not capable - but they have no choice without the software.
I do have a possible solution this end - but would like to know a little bit more.. I will ask the question about courts or klassen remote tuning out of curiosity - but would understand if they dont want to.
Thanks again and any more thoughts - especially from tuners on here - would be appreciated as i would like to know more about this stuff.
Hey Tim,
The issue with our cars is the Canbus. Gav's SRi-T doesn't have this. You could run the haltech as an interceptor but as the others have said, the stock ecu will need to remain because of the way everything is linked. There is a place up your way called BTA Motorsport that have a tool called the OPTICAN. With that tool, they are able to take the original map off so it can be tweaked and then reloaded, may be worth having a chat to them to see if they do the tweaking or wether they send the map away, they may be able to work alongside courts aswell.
Worth a shot.sigpic
Anything is possible. The guys at HP-F were told that you can never put a MOTEC onto a Chrysler 300c, guess what they did with excellent results.
It all depends on your tuner and how much knowledge they have on the matter.
Never say never i say!
