fitting fmic
  • fitting fmic
    do u guys leave ur standrd intercoller still in plaxe or take it off? heard its a bit tricky to get off so cud leave it there
    Which kit have you got?
      no took mine out came out easy
        am luking at jbi intercooler
          remove it for sure.
            surely having 2 intercoolers in place will make the cooling better?
            Whats next?!?!?
              good point
                Originally posted by vxrdave View Post
                good point
                Whats next?!?!?
                  take it out
                    its only 1 cooler you re-route pipes to new intercooler take it out if you find it easy enough might help a bit with cooling cause more air can get to rad/engine saves a bit of weight aswell but if your planning to put it back to standard when your selling you might aswell leave it in
                    black Astra VXR 08 plate 1500miles may 09
                    19" wheels, limo tints,10k HID main/ 6k dipped, 15led sidelights, full CCS retrim, insignia washer jets,cool running thermostat , intercoolers with larger powerpipe and tophat, percys airbox+ oil restrictor, scorpion full 3 inch turbo back exhaust and iridiums READY FOR STAGE 3 FIRST MAP EVER!
                      did u leave urs on mate?
                        Take the std one out when you are happy with your new setup ( ie. IC ) and this should improve slightly the airflow through the remaining rads, therefore helping to cool your engine down via the water rad.
                          rite i maytake myin out then is it hard to get out
                            Not really and you dont have to disconnect the aircon condenser btw if you are careful.
                              yeah but only cause jbl didnt have the brackets made to remove the oe cooler think they are supplying them now i'm sure they come on here you could drop them a PM or ask on ebay m8
