up rated fuel pump
  • up rated fuel pump
    for those who are running one, need abit of asvice, when you start yours up first thing in the morning do the car start up like it did with the oe pump, turn key, car starts strieght away, doesnt crank over a few times first then start?
    mines started to crank afew times before it will start, never done it before tho.
    cheers.
    sounds like its not holding fuel pressure.
      mines fine just makes whining noise constant
        its just when the cars been sat all night, an its cold, takes that bit longer to start as where it never did before..
        ive got it booked in to get it all checked over. but it isnt till next month... im not driving the car until its been checked..
          no problem with mine it starts as per normal . whats your mod list ?
            stage 3
              Yeah mine starts just as OE pump does no extra turning over.
                when the fuel pump got changed i also have the timing gear an water pump changed.
                car runs fine once started, drives fines.
