HOW TO coolant temp! with climate.
  • HOW TO coolant temp! with climate.
    Ok heres how to get the coolant temp up on the dash screen.
    The radio.
    With the ignition on. your screen should look some thing like this.
    Press the SETTINGS button & hold untill a bleep is heard.
    once you have heard the bleep you need to press the BC button 5 times untill you see this page on the screen.
    & @ Night.
    To return to the main screen just press the MAIN button.
    This will reset once the ignition is turn'd off or by pressing & holding SETTINGS button untill bleep is hear once back in the main screen.
    i got cd 30 and it dont look like that
      the principle is the same Chriss boy.
        My screen also differnet, can I really do this? What are the benefits of knowing the coolant temp as it is not oil? Is it a good thing to judge when to put pedal to the metal?
          its just an indication of the engine temp.
            is this to do with climate control?
            do you have it?
              no marc its the engine coolant temp nothing to do with air con i have cdc 30 mp3 and that the same screen as the one i have
                He means is that screen to do with climate and the answer would be yes - mine is completely different but it was on the demo, guess which had climate and which didnt
                  do you have it?
                  no i aint got climate control and my screen dont look l;ike that either dave !!!! :?
                    I thought climate was std, must not be, what is your screen like is it about half as deep.
                      same in all ways it is just the display style, different font and layout
                        Ok i do have Climate. IT was fitted to early cars as std due to the long wait for release.
                        Does it matter what the screen looks like it's for demo to show those that dont know how to do it.
                        As i have atated before the principle is the same.
                          i think you,ll find that non cc cars have larger blockier pixels and cars with cc have more pixels hence screen resolution ...
                          correct me if im wrong... :wink:
                            Not corrected as right
                              phew!!!
                              Another reason that i went for climate as display is better.!.
