HOW TO check error codes
This is a sticky topic.
  • HOW TO check error codes
    found this on AON its decent, i couldnt find ayhting liek this on here after a search so i thought i would put it on here
    if its duplicated mods feel free to remove
    - Take a seat in your car...
    - Press the brakepedal and the accelerator-pedal fully at the same time
    - Turn the ignitionkey till the lights in your dash come on but don't start the car!
    In the display where normally your mileage is shown, you'll see "ECN" (error code number) and below it the faultcodes that have been stored. They appear one after another. At the end, your mileage will be shown again.
    The first 4 digits indicate the fault, the last 2 digits contain a value.
    For example: ECN 161450: problem with communication between immobiliser and key-transponder.
    If no codes are shown, nothing has been stored!
    B0132 battery voltage high C-123
    B0132 low battery voltage C-123
    B0158 outside temperature sensor voltage is too small DIS (Information Display) C-015
    B0158 outside temperature sensor circuit voltage to open or big DIS (Information Display) C-015
    B0283 rear window heater malfunction heating, ventilation and air conditioning B-015
    B1000 replace the control unit - EEPROM errors C-002
    B1000 replace the control unit - hardware errors C-002
    B1000 control device to replace C-002
    B1000 control device malfunction C-002
    B1001 airbag control unit is not locked hardware and software B-003
    B1001 vehicle identification number is not programmed hardware and software B-005
    B1001 error programming hardware and software B-003
    B1001 Linkslenker-/Rechtslenker- configuration errors C-002
    B1001 control device is not calibrated hardware and software B-003
    B1001 control device is not programmed hardware and software B-003
    B1001 control device programming hardware and software B-003
    B1001 variants code is not programmed hardware and software B-004
    B1001 variant configuration is not programmed hardware and software B-003
    B1006 control device to replace C-002
    B1009 control device programming hardware and software B-003
    B1016 vehicle identification number is not programmed hardware and software B-005
    B1019 control device in the extradition state C-002
    B1325 system voltage power too large B-003
    B1325 system voltage power too small B-003
    B1375 Geschaltete system voltage (A ignition) is not plausible with CAN signal B-005
    B1385 terminal 15A dysfunction B-004
    B1390 comfort closure circuit voltage power too small windows C-009
    B1395 engine runs too small signal voltage EHPS (electro-hydraulic auxiliary power steering) C-003
    B1420 power supply voltage is too large C-124
    B1420 power supply voltage too small C-124
    B1421 supply voltage signal is not in the target area C-124
    B1428 relay starters dysfunction C-127
    B1441 Geschaltete system voltage (Ignition A) Power too big C-125
    B1441 Geschaltete system voltage (ignition ON) voltage too small C-125
    B1451-voltage relay equipment too large or open circuit C-106
    B1451 accessories relay circuit voltage is too large C-106
    B1453 Geschaltete system voltage (Ignition A) Power too big C-125
    B1453 Geschaltete system voltage (ignition ON) voltage too small C-125
    B2961 position ignition key switch circuit malfunction C-002
    B3601 holding magnetic key relay circuit malfunction AF 17-4 Automatic 4-speed gearbox C-005
    B3644 switch channel high wheel remote stuck RQ (Entertainment Head Unit) C-012
    B3644 switch channel high wheel remote control circuit resistance not in the target area RQ (Entertainment Head Unit) C-012
    B3645 channel down button remote control wheel stuck RQ (Entertainment Head Unit) C-012
    B3645 switch channel down steering wheel remote control circuit resistance not in the target area RQ (Entertainment Head Unit) C-012
    Scrolling right B3646 wheel stuck RQ (Entertainment Head Unit) C-012
    Scrolling right B3646 wheel circuit open RQ (Entertainment Head Unit) C-012
    Scrolling right B3646 wheel circuit resistance not in the target area RQ (Entertainment Head Unit) C-012
    B3647 switch voice remote control wheel stuck RQ (Entertainment Head Unit) C-012
    B3647 switch Voice Control wheel remote resistance not in the target area RQ (Entertainment Head Unit) C-012
    B3648 switch telephone wheel remote stuck RQ (Entertainment Head Unit) C-012
    B3648 switch telephone wheel remote resistance not in the target area RQ (Entertainment Head Unit) C-012
    B3649 Scrolling left wheel stuck RQ (Entertainment Head Unit) C-012
    B3649 wheel Scrolling left open circuit RQ (Entertainment Head Unit) C-012
    B3649 Scrolling left wheel circuit resistance not in the target area RQ (Entertainment Head Unit) C-012
    C0252 control device in the extradition condition or defect hardware and software B-003
    Wrong C0550 configuration variations programmed control unit or defective hardware and software B-003
    C0550 control device to replace C-002
    C0550 control device is not programmed hardware and software B-003
    C0551 vehicle identification number is not programmed hardware and software B-005
    Wrong C0551 variant configuration programmed hardware and software B-004
    C0551 control device programming hardware and software B-003
    C0551 variants code is not programmed hardware and software B-004
    C0551 variant configuration is not programmed hardware and software B-004
    False C0569 system hardware configuration and software B-003
    C0800 system voltage power too large B-003
    C0800 system voltage power too small B-003
    C0920 control device is not programmed hardware and software B-003
    C1523 system voltage power too large C-105
    C1523 system voltage power too small C-105
    C1550 control device to replace C-002
    P0070 sensor ambient air temperature dysfunction B-024
    P0100 air mass / volume knife dysfunction C-007
    P0100 air mass / volume knife signal too large C-007
    P0100 air mass quantities too small knife signal C-007
    P0100 air mass meter error
    P0105 intake manifold pressure sensor voltage error
    P0110 intake sensor signal is too large C-008
    P0110 intake sensor signal to small C-008
    GONE BUT NOT FORGOTTEN!
    P0110 Ansauglufttemperaturfühler error
    P0110 CAN bus, no communication with ECM (engine control unit) Fahrzeugbezogene Prüfanleitung B-019
    P0115 CAN bus, no communication with ECM (engine control unit) Fahrzeugbezogene Prüfanleitung B-019
    P0115 coolant temperature sensor errors
    P0115 engine coolant temperature sensor is not in the target area cooled engine C-002
    P0115 engine coolant temperature signal is too large cooling engine C-002
    P0115 engine coolant temperature signal is too small engine cooling C-002
    P0120 throttle valves / pedal position donor "A" is not a target area C-005
    P0120 throttle valves / pedal position donor "A" signal is too large C-005
    P0120 throttle valves / pedal position donor "A" signal to small C-005
    No P0130 plausibility between O2 sensor 1 Bank 1 and O2 sensor 2 bank 1 B-020
    P0130 lambda probe dysfunction (Bank 1 Sensor 1) B-020
    P0130 lambda sensor circuit not in the target area (Bank 1 Sensor 1) B-025
    P0130 O2 sensor circuit voltage high (Bank 1 Sensor 1) C-019
    P0130 O2 sensor circuit voltage low (Bank 1 Sensor 1) C-019
    P0135 lambda probe heating dysfunction (Bank 1 Sensor 1) B-012
    P0135 lambda probe heating open (Bank 1 Sensor 1) B-028
    P0135 lambda probe heating voltage is too big (Bank 1 Sensor 1) B-012
    P0135 lambda probe heating voltage is too small (Bank 1 Sensor 1) B-012
    No P0136 plausibility between O2 sensor 1 Bank 1 and O2 sensor 2 bank 1 B-027
    P0136 lambda probe dysfunction (Bank 1 Sensor 2) B-027
    P0136 lambda sensor circuit not in the target area (Bank 1 Sensor 2) B-026
    P0136 O2 sensor circuit voltage high (Bank 1 Sensor 2) C-023
    P0136 O2 sensor circuit voltage low (Bank 1 Sensor 2) C-023
    P0141 lambda probe heating dysfunction (Bank 1 Sensor 2) B-013
    P0141 lambda probe heating open (Bank 1 Sensor 2) B-029
    P0141 lambda probe heating voltage is too big (Bank 1 Sensor 2) B-013
    P0141 lambda probe heating voltage is too small (Bank 1 Sensor 2) B-013
    P0170 fuel correction dysfunction (Bank 1) B-016
    P0180 fuel temperature sensor short-circuit/interruption
    P0190 Mechanical fault in the fuel system failure
    P0195 ضltemperaturfühler error (at Y17DT and Y17DTL not VERBAUT!)
    P0201 cylinder 1 injector signal too large B-011
    P0201 cylinder 1 injector signal to small B-011
    P0201 cylinder 1 injector circuit open B-011
    P0202 cylinder 2 injector signal too large B-011
    P0202 cylinder 2 injector signal to small B-011
    P0202 cylinder 2 injector circuit open B-011
    P0203 cylinder 3 injector signal too large B-011
    P0203 cylinder 3 injector signal to small B-011
    P0203 cylinder 3 injector circuit open B-011
    P0204 cylinder 4 injector signal too large B-011
    P0204 cylinder 4 injector signal to small B-011
    P0204 cylinder 4 injector circuit open B-011
    P0216 Einspritzbeginn error
    P0219 engine speed is too large C-025
    P0220 throttle valves / pedal position donor "B" is not in the target area C-005
    P0220 throttle valves / pedal position donor "B" signal is too large C-005
    P0220 throttle valves / pedal position donor "B" signal to small C-005
    P0230 fuel pump primary circuit signal is too large B-010
    P0230 fuel pump primary circuit signal to small B-010
    P0235 boost pressure signal to donors large C-031
    P0235 boost pressure donor signal too small C-031
    P0243 boost pressure valve voltage too large C-032
    P0243 boost pressure valve voltage is too low C-032
    P0243 boost pressure valve open circuit C-032
    P0251 overflow valve / pump control unit dysfunction (99% pump control unit died)
    Several P0300 cylinder misfire detected B-021
    P0301 cylinder misfire detected 1 B-021
    P0302 cylinder misfire detected 2 B-021
    P0303 cylinder 3 misfire detected B-021
    P0304 cylinder misfire detected 4 B-021
    P0313 misfire at low fuel levels detected B-021
    P0325 Klopfsensor 1 signal too big (bank or individual sensor 1) B-022
    P0325 Klopfsensor 1 signal too small (bank or individual sensor 1) B-022
    P0335 crankshaft sensor wrong signal C-002
    P0335 crankshaft sensor no signal
    P0335 crankshaft sensor signal is not in the target area C-002
    P0340 engine speed error '
    P0340 camshaft position donor dysfunction C-009
    P0340 camshaft position encoder signal to big C-009
    P0340 camshaft position encoder signal to small C-009
    P0340 camshaft position encoder circuit open C-009
    P0340 camshaft sensor signal is not in the target area C-009
    P0370 pumps position signal void
    P0380 Vorglühanlage short-circuit/interruption
    P0381 Glühzeitkontrolleuchte short-circuit/interruption
    P0400 EGR valve errors
    P0420 catalyst efficiency under limit (Bank 1) B-017
    P0441 tank vent system wrong tank vent River B-014
    P0443 fuel tank vent valve open District B-014
    P0443 fuel tank vent valve voltage high B-014
    P0443 fuel tank vent valve voltage low B-014
    P0460 fuel level sensor signal is not in the target area IPC (instrument) B-012
    P0480 cooler fan (small) short-circuit/interruption
    P0481 cooler fan (big) short-circuit/interruption
    P0500 vehicle speed signal is not in setpoint range B-023
    P0500 distance frequency (employer) error (comes from ABS unit)
    P0501 vehicle speed signal is not in setpoint range B-023
    P0505 CAN bus, no communication with ECM (engine control unit) Fahrzeugbezogene Prüfanleitung B-019
    P0505 idling regulator short-circuit/interruption
    P0520 engine oil pressure switch / sensor is not in the target area IPC (instrument) C-018
    P0530 air conditioners misprint
    P0530 air conditioners pressure sensor signal is too large heating, ventilation and air conditioning C-009
    P0530 air conditioners pressure sensor signal is too small heating, ventilation and air conditioning C-009
    P0560 battery voltage error (over or under voltage)
    P0560 system voltage dysfunction C-110
    P0560 system voltage outside Area C-110
    P0560 system voltage power too large C-109
    P0560 power system voltage too small C-109
    P0560 system voltage too high C-110
    P0560 system voltage is too low C-110
    P0560 supply voltage too high C-110
    P0571 Bremslichtschalter short-circuit/interruption
    P0571 switches brake malfunction exterior lighting / flasher Appendix B-014
    P0601 control device to replace C-002
    P0602 vehicle identification number is not programmed hardware and software B-005
    P0602 injector volume adjustment is not programmed hardware and software B-015
    P0602 tires extent not programmed hardware and software B-003
    P0602 Security code is not programmed hardware and software B-003
    P0602 Control Unit C-002 program
    P0602 control device programming hardware and software B-003
    P0602 ECUs programming errors (lack of out-of-code programming or index)
    P0602 variant configuration is not programmed hardware and software B-004
    P0603 ECU EEPROM errors C-002
      P0603 control device to replace C-002
      P0604 controller error - RAM C-002
      P0605 EPROM errors C-002
      P0605 control device to replace C-002
      P0606 controller replace error (Worst Case - Total damage control unit)
      P0606 control device malfunction C-002
      P0606 controller re-initialization C-004
      P0606 system voltage too high C-110
      P0607 Klopfsensor circuit malfunction B-022
      P0607 Klopfsignal module; control device to replace B-022
      P0607 controller replace error (see above)
      P0610 control device programming hardware and software B-003
      P0615 starter relay circuit open C-127
      P0615 Amplifier starter relay temperature too large C-127
      P0615 starters voltage relay too large C-127
      P0615 relay starters voltage too small C-127
      P0621 generator control lamp arrangement dysfunction IPC (instrument) C-021
      P0650 CAN bus no communication with CIM (Steering Column module) C-003
      P0650 error display control light (MI) dysfunction IPC (instrument) B-008
      P0703 Brake lamp switch error
      P0704 clutch switch error
      P0704 clutch switch dysfunction CRC (electronic speed control) B-010
      P0725 CAN bus, no communication with ECM (engine control unit) Fahrzeugbezogene Prüfanleitung B-019
      P0725 engine speed error '
      P0815 switches High Turn the steering wheel remote stuck C-002
      P0815 switches high wheel remote switching circuit resistance not in the target area C-002
      P0816 switches Runterschalten wheel remote stuck C-002
      P0816 switches Runterschalten wheel remote control circuit resistance not in the target area C-002
      P1100 Critical System Error Error
      P1105 Barometrischer pressure sensor short-circuit/interruption
      P1105 pressure sensor signal Barometrischer too large C-030
      P1105 pressure sensor signal Barometrischer too small C-030
      P1106 boost pressure donor signal is not in the target area C-031
      P1110 vacuum tube switching valve errors
      P1120 CAN bus, no communication with ECM (engine control unit) Fahrzeugbezogene Prüfanleitung B-019
      P1120 pedal sensor 1 short-circuit/interruption
      P1120 pedal sensor 1 signal to high C-004
      P1120 pedal sensor 1 signal too low C-004
      P1120 pedal position sensor 1 and 2 false signal ratio C-004
      P1122 pedal sensor 2 short-circuit/interruption
      P1122 pedal sensor 2 signal to high C-004
      P1122 pedal sensor signal is too low 2 C-004
      P1125 boost pressure solenoid valve errors
      P1173 Einspritzmengenbegrenzung because Oeltemperatur error
      P1180 fuel temperature sensor errors
      P1195 ضldruckschalter short-circuit/interruption
      P1220 Einspritzdauer monitoring error
      P1230 main relay dysfunction power supply and communication C-013
      P1243 turbocharger bypass solenoid valve voltage too large C-033
      P1243 turbocharger bypass solenoid valve voltage too small C-033
      P1243 turbocharger bypass solenoid valve open circuit C-033
      P1243 turbocharger bypass valve not in the target area C-033
      P1335 engine speed signal error
      P1345 cam shaft speed error
      P1481 fan control circuit open 1 engine cooling B-004
      1 fan P1481 control circuit voltage engine cooling too large B-004
      1 fan P1481 control circuit voltage too small engine cooling B-004
      P1482 fan control circuit open 2 engine cooling B-004
      P1482 fan control circuit voltage 2 too big engine cooling B-004
      P1482 fan control circuit voltage 2 too small engine cooling B-004
      P1483 fan control circuit open 3 engine cooling B-004
      3 fan P1483 control circuit voltage engine cooling too large B-004
      3 fan P1483 control circuit voltage too small engine cooling B-004
      P1490 additional coolant pump circuit open B-015
      P1490 additional coolant pump circuit voltage is too large B-015
      P1490 additional coolant pump circuit voltage too small B-015
      P1500 electronic throttle author dysfunction C-006
      P1501 immobiliser coding errors
      P1502 immobiliser error
      P1503 immobiliser signal error
      P1515 donor pedal position error
      P1523 throttle author is not in the target area C-006
      P1526 throttle author lower position not learned C-006
      P1530 high voltage relay climate heating, ventilation and air conditioning B-016
      P1530 low voltage relay climate heating, ventilation and air conditioning B-016
      P1530 air conditioning requirement error
      P1530 air conditioning relay circuit open heating, ventilation and air conditioning B-016
      P1540 Climate pressure signal short-circuit/interruption
      P1560 battery voltage error
      P1560 Geschaltete system voltage (Ignition A) signal dysfunction (CAN) C-109
      P1565 interface speed control dysfunction CRC (electronic speed control) B-006
        P1600 engine torque is not plausible B-030
        P1600 control device to replace C-002
        P1600 controller error
        P1601 temperature controller error
        P1602 Maximum speed is not programmed hardware and software B-003
        P1602 programmers / Replace control unit (SG) hardware and software B-003
        P1602 control device programming hardware and software B-003
        P1602 variant configuration is not programmed hardware and software B-003
        P1603 control device to replace C-002
        P1604 programmers / Replace control device
        P1604 control device to replace C-004
        P1606 engine torque is not plausible B-030
        P1606 control device to replace C-002
        P1610 immobilizer anti-theft function is not programmed B-009
        P1610 immobiliser dysfunction Immobilizer B-009
        P1610 immobilizer function programming error
        P1611 Wrong security code error
        P1611 Wrong security code immobiliser B-015
        P1612 immobiliser signal error
        P1613 immobiliser no signal or wrong signal Immobilizer B-008
        P1613 immobiliser signal error
        P1614 Wrong transponder key error (the chip is still in the key?)
        P1614 Wrong transponder immobiliser key B-006
        P1614 immobilizer anti-theft wrong signal B-008
        P1615 ECM (engine control unit) Identification failed Immobilizer B-006
        P1616 CIM (Steering Column module) wrong environment indicator Immobilizer B-006
        Replace P1620 controller error
        P1625 relay power supply fault
        P1630 Kraftstoffeinspritzmenge error
        P1631 controller error injection pump
        P1635 Vorglühanlage error
        P1650 CAN error
        P1651 CAN error
        P1660 fuel Abschaltventil error
        P1680 coolant temperature output short-circuit/interruption
        P1690 control lamp voltage error
        P1694 control lamp voltage error Glühzeit
        P1811 engine torque signal malfunction ABS / TC / ESP (vehicle dynamics system) C-011
        P1814 Invalid signal of ECC (Electronic air conditioning) ECC / SAC (Electronic climate control) B-028
        P1895 CAN bus, no communication with ECM (engine control unit) Fahrzeugbezogene Prüfanleitung B-019
        P1896 CAN bus, no communication with ECM (engine control unit) Fahrzeugbezogene Prüfanleitung B-019
        P2638 control device to replace C-002
        U0001 CAN bus maximum configuration list is not programmed hardware and software B-003
        U0009 CAN bus communication nodes no C-005
        U0101 CAN bus, no communication with gearbox control unit C-003
        U0121 CAN bus no communication with ABS / TC C-003
        U0140 CAN bus no communication with CIM (Steering Column module) C-003
        U2100 CAN bus dysfunction C-005
        U2100 CAN bus communication dysfunction C-005
        U2100 CAN bus communication errors C-005
        U2100 No communication with CAN-bus (High Speed) C-005
        U2100 No communication with CAN-bus (Low Speed) C-005
        U2100 No communication with CAN-bus (Mid Speed) C-005
        U2101 CAN bus (High Speed) maximum configuration list is not programmed hardware and software B-003
        U2101 CAN bus (Low Speed) maximum configuration list is not programmed hardware and software B-003
        U2101 CAN bus (Mid Speed) maximum configuration list is not programmed hardware and software B-003
        U2101 CAN bus maximum configuration list is not programmed hardware and software B-003
        U2102 CAN bus (Mid Speed) maximum configuration list is not complete hardware and software B-003
        U2103 CAN bus communication nodes no C-005
        U2103 CAN bus Rücksetzzنhler overflow C-005
        U2103 CAN-bus circuit malfunction C-005
        U2103 No communication with CAN-bus (High Speed) C-005
        U2103 No communication with CAN-bus (Low Speed) C-005
        U2104 CAN bus (High Speed) Rücksetzzنhler overflow C-005
        U2104 CAN bus (Mid Speed) Rücksetzzنhler overflow C-005
        U2104 CAN bus Rücksetzzنhler overflow C-005
        U2105 CAN bus, no communication with the engine control unit Fahrzeugbezogene Prüfanleitung B-019
        U2105 CAN bus, no communication with ECM (engine control unit) Fahrzeugbezogene Prüfanleitung B-019
        U2106 CAN bus, no communication with gearbox control unit C-003
        U2106 CAN bus, no communication with TCM (automatic transmission control unit) C-003
        U2107 CAN bus no communication with CIM (Steering Column module) C-003
        U2107 CAN bus no communication with IPC (instrument) C-003
        U2108 CAN bus, no communication with ABS (anti-) C-003
        U2108 CAN bus no communication with ABS / TC C-003
        U2108 programmers / Replace control unit (SG) hardware and software B-003
        U2110 CAN bus no communication with ABS / ESP C-003
        U2111 CAN bus no communication with EPS (Electronic Power Steering) C-003
        U2112 CAN bus, no communication with CDC "> CDC"> SADS (Part Active damping system) C-003
        U2112 CAN bus No communication with CDC (electronic damper control) C-003
        U2113 CAN bus not communicate with SDM (airbag) C-003
        U2113 CAN bus not communicate with SDM (Sensing and Diagnostic Module, airbag) C-003
        U2116 CAN bus no communication with IPC (instrument) C-003
        U2117 CAN bus, no communication with DIS (advertisement) C-126
        U2117 CAN bus, no communication with Info-Display C-126
        U2120 CAN bus, no communication with AHL (headlamp control) C-003
        U2127 CAN bus, no communication with ECC (Electronic Climate) C-003
        U2139 CAN bus no communication with CIM (Steering Column module) C-003
        U2140 CAN bus no communication with CIM (Steering Column module) C-003
        U2140 CAN bus, no communication with UEC (engine room electronics central module) C-003
        U2141 CAN bus, no communication with REC (Rear electronics central module) C-003
        U2143 CAN bus, no communication with SAS (steering wheel angle sensor) C-003
        U2144 CAN bus, no communication with ACC (adaptive cruise control) C-003
        U2145 CAN bus, no communication with PAS (Park Pilot) C-003
        U2146 CAN bus, no communication with SLM (driving stage / Fahrprogrammwنhlhebel) C-003
        U2147 CAN bus, no communication with AHS (Zuheizer) C-003
        U2149 CAN bus, no communication with TPMS (tire pressure monitoring system) C-003
        U2173 CAN bus, no communication with PEPS (Open & Start) C-003
        U2174 CAN bus, no communication with AHS (Zuheizer) C-003
        U2174 CAN bus, no communication with EHS (heating) C-003
        U2181 CAN bus, no communication with elektrohydraulischem hardtop C-003
        U2201 CAN bus, no communication with RQ (Entertainment Head Unit) C-003
        U2202 CAN bus, no communication with CDC (CD changer) C-003
        U2206 CAN bus, no communication with DIS (advertisement) C-003
        U2207 CAN bus, no communication with UHP (Univ. handsfree) C-003
        U2208 CAN bus, no communication with ECC (Electronic Climate) C-003
        U2213 CAN bus, no communication with DAB (Digital Audio Broadcast) C-003
        U2215 control device to replace C-002
          your a fountain of knowledge mate
          Whats next?!?!?
            i try to help everyone btw i only found the link as carl asked the question i signed upto aon to see the link and i pasted everything here, that way if anyone searches it they will find the codes they need no need for a new thread or to do more searching if they are already on here
              I think it is linked already but it could do with being a sticky here to be honest
              Astra
                there was a link somewhere on here but you need to reigster to see it hence the copy past and new thread
                  Aah - that's just changed as you never used to have to register
                  Astra
                      What about if you have keyless entry?
                      Arden Blue Stage 2 Astra VXR on 19's. Remus, Bluefin, Cruise Control, Tints, Whiteline RARB, Eibach Sportlines.
                        press the break and accelerator pedal fully together and press the engine start button once (do not hold) and it will turn all the electrics on but wont start the engine.
                          Hello.
                          I´m a astra OPC i have te fault 30001 and 30401, and in the list I don´t look.
                          The fault is, when I run with my car fast (run to 4500-5500 rpm in 3؛ gear), sometimes the car lost power and blink the telltale EOBD and the car run as 3 cylinders. I stop the car and run the car other time and the car run correcty. The car is hot when I run fast.
                          Can you help me please?
                            Originally posted by tuanillo View Post
                            Hello.
                            Your error is P0300 01
                            and P0304 01
                            I think?
                            Astra
                              ok, tanks for you fast answer, but somebody have this same problem?
                              Thanks.
