coil springs
  • coil springs
    Can somebody advise me on the correct way the rear springs on Astra 2009 vxr should be fitted. The ones i've got differ slightly to the new ones. The spacings between coils at one end is greater than the other. They are different to the ones on car at the moment, don't know ifmthey are original. Any advise would be appriciated.
    The tighter wound closer together coils should be at the bottom, connecting to the rear beam
    The looser wound coils should be at the top connected to the body
    Should warn you though this a hotly debated topic on online forums everyone has an opinion on which way is right
    My reasoning is simple
    The tighter wound coil has more ridgidity and strength, so why would you want that side connected to the body that has very little movement and load placed upon it
    Me personally I would rather have the strongest part of the coil placed in a way that can absorb the most stress from the up and down pivot movement in the rear beam
    Seen a lot of springs fail prematurely from being placed the wrong way around at the garage I used to work at a few years ago
    Hope this makes sense
      Thanx Andy:
      Found out last night that the Drivemaster springs i got from eurocarparts are wrong even though they said they were for car with sports chassis. Unfortunately they have been fiitted to car and are now termed as non-resalable and used. On the bright side i found the proper ones on GSF carparts with the coil spacings same at both ends (same as ones that came off) and half the price that eurocarparts charge.
      Jim
        I’ve always been taught that rear springs should be fitted with the writing the correct way up and on Vauxhall’s, with the writing facing the rear of the car.
