hey folks, just thought i'd stick a few pics on of my current mods, good to get others thoughts.....and also i'm wondering if i need to buy a van for my plumbing.??.
All mods looking fab, Davy!!! Even the bath, ..top work Buddy x
any diff with brakes, im looking at upgrading pads and fluid soon then discs when need doing.
if was me between your cross over pipe and top of engine it put some heat insulation to stop any heat soak. every lil helps
cheers for that...nothing major but has made a diff, helped with fade. prob could do with upgrading hoses tho'. best of all...they where a good price.
as in brake hoses? braided ones sure can pick them up for around £50.
you can get heat insulation from BnQ homebase etc. silver foil either side with foam in the middle, cut to shape of cross over pipe and stick to the underneath, wont be able to see it and be helping in stopping any heat soak as they can get quite hot. cheap mod.
i was going to upgrade my boost pipes like yours as they look really good
but i decided to wrap them up in exhaust wrap instead as its cood air running through them from the cooler dont want it getting 1 deg warmer from engine heat, be wast of time going through the cooler
