Gearbox oil drain plug
  • Gearbox oil drain plug
    Would one need to replace the bottom drain plug of the gearbox when draining the oil? I am not sure if it is one of those plugs that only seal once?
    -=2014 Astra OPC=-
    Summit White|Aero Pack|206kW|400Nm|1530kg
    I've reused mine with no leaks
      hi ,were the drain plugs hard to get off as I was going to do mine soon
        One on top is the most difficult as you need to remove the ecu and battery
        -=2014 Astra OPC=-
          They can be pretty stuck but both are pretty easy to get to. I re-used the drain plug with no leaks.
          -Vissa-
          Current: Type R FK2 2016
          Previous: J OPC 2012
