Headlights flashing
  • Headlights flashing
    My car has the bi halogen headlights and recently whilst driving its been flicking between full beam and dipped beam without the indicator light coming up on the dashboard. It does it regardless wether the automatic main beam is active or not, anyone any ideas? Pretty much makes it undrivable because you either blind other drivers or you flash them without knowing
    Try doing a reset disconnect the battery for 30 min
      Tried it and didnt work i think a relay or something might have gone, just dunno which it is
      They are fully stuck on now
        Should probably also mention ive put in a hid kit from hids direct so im going to try swapping to the old bulbs to see if that makes a difference
          Looks like you have an issue with the Hid kit installed interfering with the can bus system.
          Sir Dale Of Yorkshire
            If thats the case then ill be after getting some money back
              Its not the hid kit, took them out and put the halogens in and uts still switching about between full beam and dipped beam
                Best get it to a dealer find out what is wrong.
                Did it do this before you fitted the hid kit.
                  No it didnt, worked fine with the hids for just under 2 months then on christmas eve it went dodgy
                    You need to get this to a dealer then as it could be many things ie switch, wiring or BCM.
                    Try disconecting the battery for 30 mins and try it.
                      Seems more likely to be a canbus error
                        Ive had battery disconneted for around 2 hours and its still not happy
                          Ok, it needs to be reset/fault code cleared.
                          I get issues like this on Jeeps and i have to do a proxi configuration realignment.
                            Update is that it has fixed itself, jad it booked in for today and thos morning it maraculously started behaving, weird
