Astra GTC VXR Steering whine
  • Astra GTC VXR Steering whine
    Hi guys, I'm getting the steering whine problem on my VXR. Vauxhall told me they thought it was because the brakes needed changing but it still makes the noise after new pads and discs (what a shafting)
    I know it has been discussed many times on here, and one solution seems to be to change the gearbox oil, I just want to confirm I have the same noise as others on here, as most of the media is no longer available on the older posts..
    I found this clip on Youtube that has my noise at 3.55 - https://www.youtube.com/watch?v=VKs-dEDhnDc&t=235s
    Can you guys confirm? Warrenty runs out next month so need to move fast on this if it is something more serious.
    I started getting a steering whine last Xmas and after some invest decided to change the gearbox oil, issue was fixed instantly.
      Was it the same noise at in the video above at 3.55?
        change the gearbox oil and refill with 2lts , when drained there is still 300ml left in, that should remove the whine , if using the car as a daily the change every 6 months or more.
        mac.
        BUZZ BLUE GTC VXR mid life crisis & loving every minute.
          I have had this whine noise also when steering. Changing the oil has reduced the noise but not fully made it go away.
            You may have the beginnings of what I had recently -
            https://www.youtube.com/watch?v=ieWhxOk9bvU
            In the end I sprayed dry lube (Halfords £6 ?) between the power steering pump and pulley - engine cold. After 5 minutes of running the noise stopped altogether. I have done about 1500 miles since and the noise is just about returning, but faint. I will spray it again but when it returns it will be time to change the steering pump.
            I had the gearbox noise 3 months after buying the car. Go on a car park and drive slowly with full lock and you will hear a sound like the gearbox is straining. Gearbox oil changed and back to perfect. I now change gearbox oil at each service.
              Car booked in for gearbox oil change on Wednesday.. fingers crossed
                Car back from garage... Short drive home.. Still making the noise.. off..
                Unless it takes a few miles for the oil to 'bed in'
                  When I had gbox noise it stopped immediately the oil was changed
                  Sent from my G3121 using Tapatalk
                    If you had it changed, who changed it? If it was main dealer they probably haven’t done it properly and have probably not refilled with enough oil. Most will refill with 2.2l to make the total amount in the box 2.5l as opposed to 1.8l and also use upgraded oil such as Fuchs Titan Race SRG 75
                    But it’s also possible the noise is not transmission related as per bottlebill’s comments.
                    I complained to the main dealer when I brought mine last year as I had (and still have) a whine between 30-40mph. They replaced the gearbox completely, so you could try your luck and report the whining, which can clearly be reproduced, in an attempt to get a new gearbox. As I still have the noise I just live with it as a feature of the car. New clutch, DMF and gearbox (all under warranty) and noise still present so gave up with it!
                      Last week I had the gearbox oil changed with two litres of Millers CRX LS 75w90 NT+. All my gearbox noises have stopped now too.
                        My local Alfa specialist who I have used for years (and trust) did it, he asked me what oil to put in and I told him standard GM based on a previous post I found on here, if anything it has made the noise worse Realised last night the car is now out of warranty, tried to extend the warranty online, put my reg in and it said they are unable to offer it for this car (such faith in thier product?)
                        I'm done spending money on this car, just had to fork out for new disc and pads, service and MOT as well as this oil change, so I will just live with it for now, and maybe find a VX specialist in Yorkshire to take a look in a few months time.
                          im confused , the thread says steering whine , your all talking about gearboxes ?? I had a 13 plate from new and it always had a bit of diff whine , VX refused to do anything about it as their manager had the same car and it also made the same noise , they just told me to drive it and if it fails they will fix it
                            My whine only makes a noise when I turn the wheel and put my foot down. So call it what u want I've just read up that it's common and caused more of a gearbox / diff problem fixed by change gearbox oil. Though that hasn't worked in my case
                              I had gearbox oil changed with the service and used VX recommended gearbox oil. Whine continued. Changed to Fuchs titan???? and silence!
