Secondary Lambda Sensor (post cat) location
  • Secondary Lambda Sensor (post cat) location
    Hi can anyone tell me exactly where to find the Secondary Lambda Sensor, its obviously after the main cat but i did a quick visual under the car the other day (admittedly not on a ramp) but couldn't see anything resembling a sensor or trailing wires. Am looking to fit a spacer to avoid the P0420 code. Thanks
    sellsey did you find it out?
      BigLukePoland Yep found it, thanks, wasn’t looking hard enough, easy to see it when it’s up on ramps. Did try using the spacer but the P0420 code came back so I went for a remap and had the code deleted.
        sellsey good, mate. Im installing decat + downpipe with sport cat. Will see how it how’s for me.
