TMS Stage 2 Boost question.
  • TMS Stage 2 Boost question.
    Hi guys! Fitted a full scorpion exhaust at the weekend and used the bluefin from TMS with the stage 2 map. Car is Overboosting to 20,21 psi (1.4 bar) and settling around 17-18psi (1.2 bar) is this normal for that map or do i need to adjust the actuator? Just seems a little high, my evo 6 used to run 1.4bar lol.
    That sounds spot on to me mate! They normally peak around 21-22psi and hold 18psi.
      Cheers Lawro that puts my mind at ease.
      Any idea if the standard clutch will be ok at this boost? Just could smell slight burning, but this could be the new exhaust and not the clutch.
        Clutch should be ok, however mine went at approx 30k miles, and I'm on standard power
        2008 - 2011 CORSA VXR - ARDEN BLUE - 18"
        2011 - 2014 Astra SRI CDTI [150] XP + 18"
        2014 -------- Audi S1, Glacier White + Quattro Exterior + other stuff
        Originally posted by Flinty
        as with every old lady, you warm her up before letting her have it
            Sounds like exhaust mate, i had that with my Remus
            Originally posted by Bobbyp90
            South East Regional Organiser
            PSN: TomFL12
              Thanks for the info chaps!
              Next mission is the cold running thermostat from courtney, should be here in the morning Doesn't look to bad of a job to fit after looking at the "How to Guide"
