Wastegate
  • Wastegate
    Hi,
    I just flashed my car with an IPF from EDS, putted a 235 ps 340nm no precat map.
    I already have a downpipe, KN replacement filter, and a Bailey dump valve.
    I wanted to know if we have to touch the wastgate, if yes how much militers the screw must exceed from the nut ? The stock mode is 11mm, to prevent any damage I have putted the screw until 9mm.
    (sorry for my bad english i'm french) thank you
    Only way to be sure is check boost compared to what EDS say it should be running.
    Mike Hughes
      he means the actuator
      Legal Disclaimer: Anything I or anyone else says about my vehicle on this website pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
        Which "actuates" what?
        Mike Hughes
          The actuater moves a rod which is the connected to your waste gate. I think
            the recirc valve.. :P
              You're joking, right?
              Mike Hughes
                  There is a how to on the corsa how to section.
                  You wind it down as far as you can until the waste gate is loose and then up again just enough secure the waste gate. That way there is no preload at all.
                  Clique #14
