Axle Stand Placement
  • Axle Stand Placement
    Hello folks, Im about to wash the car and want to take of the wheels to clean and wax them, but not too sure where to put the axle stands once the wheel is off. I have a jacking point but cant see another to put the axle stand once the wheel is off.
    Dont want to make an expensive mistake
    thanks
    anyone?
      Under the axle mate
        Originally posted by stewarty-vxr View Post
        Under the axle mate
        i did think this but didnt want to break anything lol.
        I just dont trust taking my wheel off and then getting it under, knowing my luck the jack will give up just as the wheel comes off lol
          yep. good thinkin. I was asked my a neighbour to jack up their car using their own jack.......So. loosened the nuts ever so slightly. Then jacked the car up using the standard jack as i was told to use and used the jack point.....jacked it up just so that there was enough space to change the wheel. Was just about to slide the axle stand under then BANGGGG. the jack snapped. lucky the wheel was still on. But. I was still partly under the car but was dead lucky. Definitely use axle stands bud. I had a blow out on thursday in the van and refused to change the wheel without a axle stand
            ive taking off all the bolts but the wheel wont come off
            tried pulling it but it wont budge, is there anything else that needs to come off first?
            im not very good with this sort of stuff lol
              kick it. the rust has maybe half welded it to the hub. be careful tho
                still nothing, annoying as hell lol
                just will not budge
                They were recently painted, maybe they put them back on slightly wet and its stuck
                  just will not budge
                  mmh. thats probably what it will be. i've never had the corsa 1's off yet. will be coming off next month tho for a wax. u have definitely got all the bolts out
                    mine lifted off... no problems... try some good'ol WD40 lol
                    Originally posted by Bobbyp90
                    South East Regional Organiser
                    PSN: TomFL12
                      lol yup, defo out
                      5 bolts all out and no movement
                      will keep trying, will be time to stop by the time they come off
                        Give a good kick they must have stuck on they should literally fall off when all the bolts are out
                          I had to call out the aa for the same thing. They used like a big rubber hammer few hard wacks and they came off.
                            yup brue force and ignorance will get it off
                            Tech2 Diagnostics
                              got one off so far
