Cd stuck!
  • Cd stuck!
    Well I was listening to the cd last night! Turned the car off! Turned it on in the morning and the radio came on! Pushed the cd button and the screen says cd error! Pushed eject and it's says eject cd but nothing! How can I get it to eject? It's a proper cd and not a copy! I have seen one other thread on this but I don't want to take the cd player apart!
    Can anyone help?! I hate listening to the radio! Lol
    Also how long the warrenty on the cd player?
    Warranty should cover it for the full 3 years surely if its faulty? not sure on that though.
    Have you done a search on forums for other ways rather then taking it apart?
    Corsa VXR Arctic Edition
      smash it hard with a hammer
        Had the same problem in a Ford with a 6 cd changer in the head unit a few years back and the only solution was to pull out head unit to get to the changer and manhandle the cd out from there
          The warrenty will cover it! I phoned vauxhall but I ain't allowed to open up the head unit and nor are they! They have to send it off to the manufacturer! If I or vauxhall open it up then the warrenty is void! I'm waiting back to hear from them whether I can just give them the head unit!
            Exactly the same happened to me Friday, has happened twice since Ive had the car, the first time it gave me my cd back after a week, luckily this time I was booked into vauxhall for a service on the Saturday so I told them and there ordering me a new unit, best thing to do is take it to them if your still under warranty and let them order a new one for you otherwise be patient and hope it spits it back out in a couple of days and hope you don't have the same problem again.
              Oh right! Thanks! I'm hoping it sorts itself but if not then I will take it to vauxhall!
                This happened on my old c. Stayed in there for 2 or 3 days then just have it back!
                #weusedtobetheshit
                  Sharing is caring lads, let your CD unit borrow the CD
                    Then after did it just work as normal or did it need to be replaced?
                    fair enough, can keep it for a day or 2! Lol
                      happened to me before, I reset the battery and the cd popped out straight away
                      My Progress Thread : http://www.vxronline.co.uk/forum/showthread.php?t=55899
                        Ok cool! I wil give that ago when I get a chance! Did the cd player work fine after? And did it need to go to vauxhall?
                          mine has done this a few times too mate, don't worry too much. As above, reset the battery and it will work fine again. You shouldn't need to go to Vx, guess its just ANOTHER common fault!
                          Astra Edition #105
                            Oh right! I've never heard of this issue before! Lol
                            Thanks for all the responses guys and gals!
                              you reset your batt and tried it?
