brake Hoses from thorney
  • brake Hoses from thorney
    hi,
    i just bought a brake hose from thorney, for a complete set, how many hose should i receive? 2 hoses for front and 2 hoses for rear?
    because my garage said should hv 4 rear hoses, 2 for rear left and 2 for rear right.
    thx
    OPC from HK
    No only one per side! They should replace the rubber standard section of pipework and just screw up with the banjo bolt at the end of your braided hoses from thorney. Have a look on your car through your wheel and you should be able to see where they go
      this one,right?
      OPC from HK
        i got my hoses from courts and i got 4 hoses for the rear
        STAGE 6 Courtenay intercooler, Quaife lsd, 3" exhaust, Percys tophat, gt28/68 hta, custom made parts, Whiteline rarb, DAP springs, Courtenay 16 grove discs, Mintex M1144 pads, stainless braided hoses, brake cooling ducts, 5.1 dot fluid, Insignia washer jets. over400bhp and 400f/lbs Courtenay tuned.
          corsa VXR?
          OPC from HK
            two for the front, two for the rear axle and two for the rear calipers,
            6 in total
              Sent TMS a email or call them unless they do it this way to cut costs
              the truth is out there
              part GSI part VXR
                4 hoses for the rear i got
                  I agree, Its 6 in total. 2 for the front, 1 per caliper and 4 for the rear, 1 per caliper and 2 for the rear axle. (1 per side)
                    ic
                    are the hose for rear caliper and rear axle the same?
                    OPC from HK
