Tyre pressure help
  • Tyre pressure help
    Couple of quick questions.... I'm away from home so don't have the manual to hand, so go easy on me!
    First, what tyre pressure should I be running on 225 35 18s? Is there a sticker in the car that tells me this?
    Second, how do I reset the tyre pressure monitor thingy after I've put the correct pressure in? Do I press and hold for a few seconds?
    Gary
    Gary
    Yes, on the inside of the Petrol cap
    Alternatively...
    http://www.vauxhall.co.uk/content/da...nual_Jan09.pdf
    And yes again, hold for a few seconds
    Originally posted by Bobbyp90
    South East Regional Organiser
    PSN: TomFL12
      Ahhh - inside the petrol cap!! That's why I couldn't find it inside the door!!! Lol
        On 18s people say 38 front 35 rear don't know if this is right though
          Yeah, I put that in today - but there was nothing inside the filler cap??
          And is it just me, or does 38psi seem a bit high??
          What's everyone else running on 18s?
            35 on front 32 on back mate
              The general psi on Tyres is about 32. Alterations are down to the car load and personal pretence if for performance. Should have all the pressures in the manual though mate.
                The manual quotes 38 front and 35 rear...!?
                  As I said it depends on the car and it's load, performance etc. Just go by the manual mate unless you are certain of any benefits to be made from different pressures. Which I'd love it if you could even see a difference on the road from 1-2psi difference.
                    17s 35psi all round. works a treat.
                      32 psi alround
                        you sure thats not for a full load cause my manual says 1-3 people 35 front and 32 rear mate ?!
                          It depends what version of the manual you have. The more recent manuals state 38psi front, 35psi rear for up to 3 people for 18" wheels. Earlier manuals stated the lower 35/32 pressures.
                            Mine states 38 front 35 rear which I use no probs.. Puttin it at 32 Wud surely be a bit risky being as it's a lot lower pressure?
                            No VXR
                            Abarth and a 330e
