Cool running thermostat
  • Cool running thermostat
    hi,
    will this thermostat linked below fit on an 09 plate corsa vxr?
    http://cgi.ebay.co.uk/VAUXHALL-COOL-...item2eb4ab8b4c
    thanks
    jack_vxr
    send the seller a question asking. Then if he says yes and it doesnt you can get your money back. If someone says it does on here then it doesnt you aint gonna be able to get ya money back.
      I got mine of Regal. Courtney also do them. I'd just get it from them as you know it will be a OEM part and will fit etc. Mine was £28 I think. Well worth the money.
        +1 indeed mate. Got courts to fit mine when was having the stage 2 done....
          pay a few pound more and get the right one from a tuner or vauxhall mate.
            +1
              ok thanks guy's, I will get one from a tuner
              jack_vxr
                Is there an advantage of putting one of these on a standard VXR?
                  Yes there is. In theory it keeps the engine cooler (which it deffinately does), but at a high enough temperature for using full boost so should prolong the life of engine parts etc. Also (in theory) a colder engine runs with more power, you won't see any gains but if the hypothesis is correct there should be some difference shouldn't there?
                    def i would highly recommend.
                    thay are fitted as standard to all opels in hotter climates
                      How difficult are the to fit? I think I did ask this before :s
                        Anyone know the part number of the one that fits Astra's so I can order one from Vauxhall?
                          Pretty simple. There is a how to. Just be sure you have enough coolant to refil the whole thing or you're stuck as you will loose it.
                            corey lad what do you do for a living dude?...... hypothesis what does that mean lmao!
                              go on regal or courts mate as theirs is a gm part and i think is the same price
