r spec boost gauge
  • r spec boost gauge
    hi has any 1 got the boost gauge from r spec the stepper motor 1 i need help wiring it up i have wired the red wire into the red yellow wire in back stereo and black and red into cig lighter and it doesnt work please could you help.
    Is it only two wires you have not three?
      its got 4 wires i only used 3 red black and white
        take the red wire thats on your radio at the min and change it to the thin black wire on the cig lighter job should be a goodun
          so i got white wire going to brown wire in cig lighter and red and white wire to black wire in cig lighter
            i need to know what the wires are for mate as different make gauges use different colours
              red - battery +
              black - battery -
              white - note
              orange - note
              thats all its says
                red - battery +
                black battery -
                white - note
                orange - note
                thats all its says its a r spec gauge in psi thanks mate
                  is it a electical gauge with a sender?
                    yes mate it is
                      red to swithed live (small blick wire on the cig lighter)
                      black to earth
                      i would say white is to the sender
                      orange is the dimmer for the lights (not needed)
                      if it works and is not givin a reading change the white for the orange one.
                        sorry mate thought u ment little black box tha the vacum hose conects to
                          im lost now mate lol
                            i got the 4 wires red black white orange red is + black is - and white and orange just says note i got the red wire going into red and yellow wire in back stereo witch i think is ignition live and got black wire into little black wire into cig lighter and red wire into the brown wire in cig lighter thanks for your help mate dont see why its not working
                              right pull it all out befor something burns out its all wrong!
                              the red wire on the gauge goes to the thin black wire on the cig lighter (this is a swithed live and not an earth)
                              the black wire goes to the thick black (i think its black or brown) on the cig lighter or to any earth on the car
                              the white wire goes to the sender the sender sould have an earth that needs earthing to.
                              should work then mate.
