slight noise
  • slight noise
    hi. ive got a noise sounds like a wheel bearing only when i pull off after parking for a little while and only for about 10 seconds but its anoying. any ideas.??..
    could this be the dual mass flywheel.??
      is it a clicking noise?
      could be the abs self test
      corsa arctic edition #257
      now sold
      REAR STRUT BAR FOR SALE!
        ABS self test, all corsa vxr's do it. Should sound like a slight knocking noise.
          Don't suppose its the brakes sticking on?
            no m8 sounds like a wheel bearing / humming noise..
              Could well be ABS self test.
                it is a bit annoying though thought id ask thanks..
                  If it only does it when you are pulling off for the first time after turning engine on and doesnt do it again when you are pulling off at lights etc then It is abs as it does check first time you pull off and get to about 10ish miles per hour, it won't do it again till you turn engine off and on and pull off... If it does it whenever you are pulling off from lights etc it's something else...
                  Used to own: Arden Blue Astra VXR.
                  Now own: Silver Corsa VXR.
                    thanks. yes it is abs self test..
