Forge actuator
  • Forge actuator
    Need to know wether you can use the updated forge actuator on the corsa using eds and running 250bhp?
    Bump anybody?
    It should be fine shouldn't it??
      im sure its fine, just depends what spring you put in
      corsa arctic edition #257
      now sold
      REAR STRUT BAR FOR SALE!
        Yea put the stronger spring in and leave on same setting that it's on now about 4-6 threads from bottom
          ring forge mate, i would think it would make no difference tbh
            Rang the company brought from and Said what psi I was running and power and he's sorting the internals out
            Hopefully comes 2mo ready for pvs
              Would you actually see this when fitted?
                Ye will be able to see it.
                I've got a crome heat shield so maybe not but it's terr for performance not looks
                  Is the Forge recirc seeabke when fitted also?
                    Not really mate.
                      Fair enough. I have loads of stainless covers coming any day hopefully so just going for looks at the minute.
                      Got stainless battery, large and small fuse box, brake fluid and top wire covers. Heat shield, forge hoses, forge intake hose and blue conduit.
                      Also sent a pm to someone about buying a forge header tank. I hope it looks as good as I planned!
                        Does anybody have one of these for the Corsa?
                        I'm confused whether you adjust the actuator by changing the springs or the dame as standard "winding the nuts off, pushing lever down etc"?
                          The recirc valve shouldn't have anything to do with the turbo wastegate.
                          There's are stiffer springs for the recirc valve for more tuned engines.
                          Afaik the valve is just to replace standard crap one no performance increases.
                          I've not heard of adjusting waste gate actuator unless using an eds map
                            He's referring to the Forge Actuator upgrade not recirc
                              As above mate, i have a recirc just looking at the actuator also.
