Hey guys just wondering. When i pull off the line in 1st in a spirited way does anyones car have a real kick or jolt goin into second when u put full throttle on again.
I find that not hitting the overboost in first gear and flooring second helps a lot
yh i think when i give it a little too much in 1st theres a real shunt into 2nd lol, i do tend normally to get it into 2nd around 4,000 rpm in 1st then go all out,
lol
lol
I get it. Try not going so high up the revs in first.
Also don't dump the clutch when changing or it will jolt in and can give a bit of wheel spin as you get into 2nd.
