i recently spent 7k at regal having high comp pistons, cams, astra injectors, astra afm, oil cooler, solid flywheel, uprated astra vxr clutch, wavetrak diff, timing belt kit, water pump (which i payed for but wasen't changed) and since having it back coverering 3k the oil cooler was loose 2 out of the 4 bolts missing, sump leaking (gasket) headgasket going within 2 weeks which i changed myself as they are 3 hrs away, gasket missing between the exhaust and turbo and for some reason i'm loosing water but i can't find where i replaced all the water pipes including the heater matrix pipes car covered 40k before the rebulid with no issuies at all i've rang regal 3 days ago and left my number as chris was out and haven't recieved a call back??? i want big reliable power can anyone point me in the right direction with the mods i already got this is not a go at a tuner this is all facts and i just want it right...
7k at regal help plz
As Burt says get it straight back to then don't sound like you had a great regal experience .
should have went to courtsavers...
serious note get it trailered back to them and charge them for the costs, cant believe you spent all that and they have not called you back!
surely they should have gice it a good run before releasing the car mate?
i had problem with mine not starting after spending ££££, took it straight to them and next min its repairedworth the trip i was 2 and a half hous away aswell
arctic 212, stage 3 regal with all extra'sNow for sale, £9500 ONO all thanks to my penus lol
I'd be suprised if the exhaust gasket was missing.... Also when you did the head gasket did you use new head bolts etc?
Since the rebuild did you actually run the car in?
Clique #14
Originally posted by tommylarge02 View PostNice list of mods mate same as me except the rebuild
As said if there's something wrong take back to regal and they will sort it out for you
Originally posted by Rabbid View PostI'd be suprised if the exhaust gasket was missing.... Also when you did the head gasket did you use new head bolts etc?
Since the rebuild did you actually run the car in?Last edited by THEVXR1; 23 June 2011, 11:18 PM.
steve you told me you found a split in the plastic stat housing that you could not find last week,and you were going to change it yourself,also mate hitting temps of 130 degs because of water loss will not help your head gasket.
mate get it back down if you need it looked at, also you told me you are still driving it,so drive it down.sigpic
Originally posted by THEVXR1 View Postalong with drilled 345mm discs, porsche calipers, forge intercooler, 3" piper full system ect ect just want it right was going in for the gt28 and manifold along with stiffer valve springs metal induction pipe ect but not sure what to do now after all the problems...
Stronger valve springs? Get a pic of your car up mate. And yes carry on with it now mate
