problems
  • problems
    my gear box has just started to wine when i pull away from a stand still and
    when i change gear from 1st to 2nd it sometime crunched aswell whit the clutch peadel full pressed down and
    in 3rd and 5th gear when i accelorate my gear stick moves back and fourth
    i was just wondering what the problem is i was thinking clutch realeas bearings or is it just a warn clutch or new gear box
    any help in this matter would be helpful thanks
    Regal dare devil AST's, Nortech manifold Garret GTX28 turbo.
    RSS Corsa
    BBC#29
    Could be a straight forward gearbox problem mate; mine is currently up for discussion on replacement
    Originally posted by Bobbyp90
    South East Regional Organiser
    PSN: TomFL12
      Sounds like the synchros/diff are worn. You may need a replacement as vx won't replace anything inside a gearbox as it's cheaper to just replace
        Its the bearings worn in the gearbox thats what gives the excessive movement in the gearstick especially in 5th. The sooner u get it looked at the better. If it fails completely then it will be a complete new box.
          thank you all for your replyes but what about the problems i got aswell any body know
          RSS Corsa
          BBC#29
            New gearbox by the sounds of it bud, just had mines done for the lovely whining sound.. Had survived 37,000 miles
              ye mine has just hit 31,000 miles
              RSS Corsa
              BBC#29
                what do you mean excessive movement in 5th ? it shouldnt move at all if its in that gear ?
                Legal Disclaimer: Anything I or anyone else says about my vehicle on this website pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
                  wow these are realy made to last................ not. i think mines whining on top of everything else thats wrong with it
                  Arden corsa Vxr = TMS stage 2=(227.8BHP)
                    If it's whining it's the diff worn or it's low on fluid! If it snaps out of gear or crunches when selecting it's the synchros. If it's diff then just replace with a LSD and new bearings. If it's synchros then it needs a gearbox rebuild and probably cheaper, easier and quicker to get hold of a good condition used box. The gearboxes are prone to leaking fluid out so have a look around the bottom of the gearbox and see if there's fluid or get it checked and topped up if necessary. If it's driven without fluid then it will blow the diff out the box or cause damage to synchros
                      Don't understand how the whining means its the diff mate.
                      I still get whining and ive got and lsd and changed my oil..
                        yes me too i only had my lsd fitted at the beggining of june by my tuner aswell so i know it has been done well and would i lose that much oil in such a short time
                        RSS Corsa
                        BBC#29
                          Well I was a mechanic for a few years and decided to do something else so I know what I'm on about. It was a suggestion to what the noises "normally" are. If the diff has only been fitted for a short while then it possibly isn't that. Let's face it..there isn't much to a gearbox apart from synchros, diff etc etc but do to the nature of how complicated a gearbox is inside it can't be rebuilt by a normal garage normally, it would be sent off to a specialist. When you bought your car new it wouldn't of whined?....so that indicates there is defiantly a problem. If you take it to get checked they will only say one of the above what I have already said.
