Tools for lowering springs...
  • Tools for lowering springs...
    Fitting my springs tomorrow. Know what i'm doing also got a friend to help me.
    Just want to make sure I have the correct tools as i've left all my swan neck spanners at work.
    What tools do I need and sizes?
    Muchos gracias!
    Good luck mate sorry to crash in...
    I don't know what tools you need..
    Do you know where I can get 20mm springs from?
      No worries buddy!
      Err Eibach are like roughly 15-20mm.
      You can get 30/20mm springs.
      Also Regal (Pi) and Spax do 20mm all round springs.
        I have some real issues with geting on me drive..
        Do you know what the softest are? Lol
          Softest? Surely if you have a problem with ride height you want harder springs to stop the drop rate?
          Also I have a stupidly steep drive and live on a hill. I also park two wheels up a curb and have many speed bumps to drive over. What I did is parked my car up with the lowest parts of the car above the highest things I may drive over then measured the gap. I actually realized it's a bigger gap then you'd expect.
            Well the bottom of my bumper is scratched to 5hit
            How low you goin?
              How low you goin?
              Dap Rs mate, 30mm.
                K cool. Av fun fitting em
                  2x18mm bolts on shocker leg to hub, 18mm nut on anti roll bar linkage (there is also a recess for a spanner on the back side of the link to stop the nut rotating), the top mounts are T40 torx with a 18mm nut.
                  Rear just loosen lower bolt on damper...with the wheel off get someone to put some weight on the hub and pull spring out. I'm sure the rear damper bolt is 17mm.
                  You probably know how to do the rear springs but I thought I would tell you anyway. I'm sure it's forecasted Storms tomorrow in derby so your not far away so may be there too. Good luck
                    I'm back Corey, would you have any pics of jacking points and axle stand points by any chance? Thanks
                      I'll get for you mate. If you look under the car it is fairly obvious. Also you can jack both rests together if you get it level.
                      Cheers for info 888.
                        I think I know Jus wanted to make sure, don't wanna break it
