Please Help Boost Problems
  • Please Help Boost Problems
    Hi All
    I have sudden loss of power, think I have a boost leak have checked the obvious but now I'm scratching my head as I have run out of ideas
    You can hear hissing when starting up and the pressure emptys out when you turn the car off
    I'm in Birmingham can anyone recommend the best place to take the car to be looked at ?
    Any specialist in the area
    Sounds like a simple vacuum pipe leak. Check the vacuum pipes coming off the inlet. 99.9% sure its that.
    Arden Corsa VXR
      checked all pipes turned out to be the Recirc Valve, seals had worn :-)
