Corsa vxr turbo oil leak???
  • Corsa vxr turbo oil leak???
    right I have just found a oil leak today I was away to change fog light bulbs and spotted oil all over the intercooler pipes I thought it was the rad coolant at first but nope it's coming from the turbo, the pics are very poor but you can just see, can anyone tell me where and what's leaking and what's the best way to fix, new unit or seals?
      https://flic.kr/p/BF9y6N
        Have you checked the oil return pipe on the turbo I had a slight leak on the pipe due to the copper washer
        WG Motorworks Fully forged Astra Vxr Arctic ...
        Rabbid tuned... TD Stage 3 hybrid, Piper valve springs, piper cams, klasen inlet manifold, Courtney cdti conversion, Airtec front mount intercooler, 3" scorpion exhaust, Turbosmart actuator, Forge recirc valve, Quaife LSD, Helix Clutch & SMF, Rear anti roll bar, blue & red SMD conversion , bi xenons and CD70
          no not yet booked into the garage next Wednesday so will find out then, for now no boosting haha
            As said before, looks like its coming from your oil return
            this is a quick and easy fix just need a new gasket there few quid from ebay
            Would like to know what the garage try charging you
            Good Luck
            Clique 19
            Jacob Newman
            Rabbid Tunned 375BHP 330FTLBS - GTX2860R Shed Build
              yeah I can't wait to see what they say, I've had a look and probably is that gasket will update when I know more cheers
                I'm guessing this is the gasket I'll need ?
                  Yes
                  Sent from my Nexus 5X using Tapatalk
                  White VXR Clubsport.
                    nice I'll order one just incase it is this
                      Link for the gasket? I have the same issue.
                        I bought it from eBay must of been from someone that had one in there garage as it was a one of, I couldn't find another easily
                          390861576634 try this item number eBay
