Gearbox Problem
  • Gearbox Problem
    Hello,
    Im quite new to the forums as ive only had my VXR for a week, cant seem to find my answer through other threads.
    Whats happened is whenever i go into 3rd gear it just drops back to neutral. It drives fine in any other gear.
    Ive not noticed any sounds & the car has driven fine, just started happening today. I Know the previous owner, so i dont think ive been given a bad deal here when i bought it.
    Does anyone have any idea what it could be & how much it would be to fix? Thanks for any help given
    Does it do it as soon as you press the accelerator in 3rd, say if your just rolling in 3rd it will not pop out of gear?
    If so I'd say it needs a new 3rd gear I had this problem but in 2nd
    WG Motorworks Fully forged Astra Vxr Arctic ...
    Rabbid tuned... TD Stage 3 hybrid, Piper valve springs, piper cams, klasen inlet manifold, Courtney cdti conversion, Airtec front mount intercooler, 3" scorpion exhaust, Turbosmart actuator, Forge recirc valve, Quaife LSD, Helix Clutch & SMF, Rear anti roll bar, blue & red SMD conversion , bi xenons and CD70
      Yeh only when i go to accelerate
      That doesnt sound too bad - was it a quick fix?
        Depends what you mean by a quick fix as the gbox would need to come out and 3rd gear to be repaired
        • Arden VXR • Stage 3.5 • Launch Control + Ignition Cut • K04 Hybrid • Full 3” Decat Scorpion Exhaust • Forge FMIC • EDS Inlet Manifold • Forge Top Hat • Pipercross Cone • Turbosmart Actuator • Turbosmart Recirc Valve • Vibratech Engine Mounts • Blue Hoses • Bonnet Vents • Lowered Coilovers • Team Dynamics 1.2 • Drilled & Grooved Discs • Ferodo DS2500 • ATE Typ 200 • Carbon Fibre Wing Mirrors + Dash + Speedo • Vent Boost Gauge •
          Yeh thats what i meat, just what would need doing.
          Ive been quoted at £600 inc VAT to fix this problem or £650 + vat for the uprated m32 gear box. Does that sound about right/is it worth going for the newer box?
            Have you tried draining the gearbox oil and putting in a decent quality oil first before you go spending big money on a new box, Fuchs Titan syntofluid 75w 80 is supposed to be the best for this gearbox so try that first as they do need good oil and it may never have been changed, also if you drain it and there's bits of metal in the oil the I would go for new gearbox at £650
              Cheers for the help.
              Ended up taking it to a garage. 550 for new gear and bearings to sort this out.
