Secondary decat and mid silencer delete
  • Secondary decat and mid silencer delete
    Has anyone had the secondary cat and the middle silencer removed from a standard system? How does it sound? Any videos?
    How olds your car, which engine??.
      2012, a16 engine
        http://www.vxronline.co.uk/forum/sho...se.&highlight=
        Secondary cat left alone and main cat removed, but some info with a video there.
          I did that on mine, didn't make too much difference to noise.
          No videos sorry. Backbox hides most of the noise as far as I'm aware.
          Sent from my C6903 using Tapatalk
            Cheers guys... nasir would you say it was worth doing? Or better saving to get a proper system?
              Its made a massive difference on mine mate. 2.5" Cobra non res catback, left the secondary standard cat alone and 2.75" decat downpipe, its fair to say the difference is great. I don't like the pops but it does it and from 3.5rpm the sound is great, but subtle enough when driving normal.
              And for the record, the back box will amplifie all the pipework before it. With just the catback it sounded tame, decat was the key and compliments a decent rear end.
                I got a custom cat back with 1 silencer and secondary cat removed (a16). It's not massively loud but certainly picks up when you're heavy on the throttle and turbo kicks in
                Sent from my MI 5 using Tapatalk
                  https://youtu.be/lTR0kf2dnlY
                  Doesn't really do it justice
                    Would want to keep the main cat in, not looking for it to be massively loud just want it to sound a bit better
                    So the custom you got made is from the main cat back, deleting the secondary cat and just with 1 silencer?
                      If you are planning to keep the standard backbox then not worth it, but if you are replacing the backbox as well then probably worth doing.
                      I'm currently using the standard Burg backbox until I can find a decent and cheap enough backbox/catback.
                        Which back box would you recommend? I know remus seems to be the most common, but any other good ones?
                          Full system would be ideal for best sound rather than just the backbox, but I'm keeping an eye out for something like a piper one as I've heard they are nice
                            You also have cobra and milltek, they are most talked about on here
                              Cheers mate, will have a look and see what I like
