corsa vxr gearbox
  • corsa vxr gearbox
    hey guys just wanted to ask a quick question i heard that the vxrs have a commen gearbox problem is there any way of fixing it permanently or upgrading the gearbox i am thinking of buying a vxr so wanted to know
    It's normally the 6th Gear shaft bearing which goes, (which sits at the end of the shaft on the end casing side). It's due to lack of lubrication and therefore overheating.
    You can get this bearing replaced and get a modified end casing which houses a better lubrication system which generally sorts all the issues out.
      Link to this or now where to get one?
        http://www.courtenaysport.co.uk/buy-...prod_1336.html
