has my corsa got cruise control or not ,over on the astra vxr side they are threading on how to put it in.i thought it was standard on a corsa vxr
hence why the thread is not on the corsa side with the astras its an extra or at least used to be but it infact worked out cheaper to order car without it and get garage to put it in after i believe.
When your in the car next, Drive away as normal, you have to press the brakes at least once for cruise control to be able to engage.
On your indicator the end bit should twist, twist it away from you and cruise control will turn on, to turn it off, press the button on the end or, press the brake or clutch pedal in
i love cruise control... makes my drive to/from work soooooo much easier... took it on a good run a couple of weeks ago using it too. beautiful invention!
