How easy is it to wire a sub up to the unit in the corsa?
Sound system in corsa
Originally posted by LittleMissCaz View PostHow easy is it to wire a sub up to the unit in the corsa?
and about an hour of ur time if thatAstraEdition #105
Originally posted by W6 PHL View Postcan you connect a sub to the standard 1 then, has it the pre outs and remote for the amp
u need a "rca to speaker" lead...then jus match the wires to the colours on the speaker leads, join em up and voilaaa...a sub out lead
and as for the remote that just connects to the live so ur sub will always b on when the head unit isAstraEdition #105
Excellent, that's my next challenge when it stops raining! If I can wire one into my old pug I'm sure I can do it in the vxr. Miss having my sub so much... just not sure if it will fit in the boot... that's the only problem at the moment!!!!
Originally posted by LittleMissCaz View PostExcellent, that's my next challenge when it stops raining! If I can wire one into my old pug I'm sure I can do it in the vxr. Miss having my sub so much... just not sure if it will fit in the boot... that's the only problem at the moment!!!!AstraEdition #105
